Question about Lexmark JetPrinter Z22 Color InkJet
I have a lexmark Z22 color inkjet printer. the problem that i am having is when i turn the printer on, it doesn't load the paper right, and then the power and paper light start to blink simultaneously and it won't print what i want it to print. when i turn the power off, it sucks the whole pile of paper through, then shuts off. what is going on? signed, trouble with printers, Arghhhhhh!
  • 14 Answers
You may try the following for the paper feed issue:
Firstly, ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, you may try these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
hope dis solves the issue.. try it out..!!
Posted on Apr 22, 2009
How do I install Lexmark Z22 onto my Windows XP Pro computer?
Download the driver from the lexmark website located here.
After you download it then go into the add printer wizard and install the driver from there.
Sep 22, 2010 | Lexmark JetPrinter Z22 Color InkJet
I want to install lexmark z22 without cd. how can
You could try going to lexmark.com and see if tey have any way of doing it on line otherwise you may have to purchase a disc from them. Most printers you can get updates and drivers (sometimes) on line otherwise you need the actual disc to install the printers on your computer.
Nov 12, 2009 | Lexmark JetPrinter Z22 Color InkJet
Have a Lexmark Z22 printer that skips lines while printing
One of your cartridges is plugged up..take it out and gently remove any excess ink from each cartridge hole with a napkin and try again..
May 28, 2009 | Lexmark JetPrinter Z22 Color InkJet
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Lexmark Z22 Printer Problem
It´s probably a configuration problem , ralated with the parallel port settings. Tell me what Operating System are you using.
May 02, 2008 | Lexmark JetPrinter Z22 Color InkJet
High Voltage Power
I would assume if your printer was hooked up to that high a voltage you would need to buy a replacement part for the power supply. Lexmark website states to replace it with a "Class 2" 20 volt dc at 500ma. Basically you just need to contact Lexmark and get the part and have a printer specialist install the new power supply. You could also try another power cable as well. Sometimes the cable is just fried and nothing is wrong with the printer.
Apr 30, 2008 | Lexmark JetPrinter Z22 Color InkJet
Printer not printing
print the test page from properties if it comes clearly ,reinstall the microsoft office and check otherwise post the details of your printer
Mar 16, 2008 | Lexmark JetPrinter Z22 Color InkJet
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
CANNOT INSTALL Z22
llucola:
The spooler service can be started following these directions.
Go to start
Go to run
In the open box type: <cmd> without <>
When the command prompt opens
type: net start spooler <Enter>
This should say that the spooler has started successfully.
Jess01: A driver is basically a communication device between your print device, which is your hardware "meaning can touch it" and printer software that is the language that your print device and computer can read. Your USB cable let's the computer know that your printer is connected. The software is needed so the printer has the language to be able to print what you tell it to.
If you have windows 2000 or xp.
Go to this website.
http://www.nodevice.com/driver/Z22_Color_Jetprinter/get31830.html
Scroll down the page 'til you find Lexmark Z22 Color Jet Printer
To the right you will see "download"
Click the link.
Scroll to the bottom you should see "Please enter verification code"
Type the code in and click "download"
Click save.
The software should then be downloaded to your computer.
Go to the location you saved the printer drivers.
There should be a setup file.
Click on that.
The printer should then be recognized and you should be prompted that the printer is going to print a test page.
Nov 05, 2007 | Lexmark JetPrinter Z22 Color InkJet
Lexmark JetPrinter Z22 Color InkJet Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
