Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a Hayward H series gas pool heater eith electronic ignitio
It heats for awhile then stops and I get a SF code
  • r_kiel Apr 22, 2009
    There isn't any debris. To reset the heater do you turn the heater off and back on using the panel inside the house?
    How do you check the thermostat?
    Richard
    I replied but did not get an answer?
    Richard
  • 11,896 Answers
Here is a schematic for your heater;I have a Hayward H series gas pool heater eith ele - c158f9a.jpg
Posted on Apr 23, 2009
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Apr 23, 2009
    To check the thermostat, you can use an ohmeter and place black probe on neg side and red probe on positive side. While turning thermostat, see if the meter increases. If it does not increase while you turn up temp, than it will need to be replaced.
  • Nate Stansfield
    Here is another
  • Nate Stansfield
    I viewed the limited technical material that I have available on this
    spa heater. The thermistor is the temperature sensor. Since you
    replaced the thermistor and still have the problem, it is likely that
    your failure is either in the wire harness between the thermistor and
    the control module of a failed control module. If you have a volt/ohm
    meter, you can disconnect electrical power and check the resistance
    through the wiring connections for the thermistor that plug into the
    control module. Most thermistors will measure high resistance such as
    10K ohms (10,000 ohms). I don't have the resistance specification for
    this thermistor. Check the resistance directly off of the leads of the
    new thermistor. If the resistance readings through the wires that
    connect to the control board for the thermistor match the resistance
    measured directly at the thermistor, then the wire harness should be
    okay. This would indicate that you would need to replace the control
    module. If the resistance through the wire harness is different
    than the resistance measured directly off of the thermistor (such as
    open, or infinite resistance), then the wire harness would need to be
    replaced to correct this failure.
    These are general
    troubleshooting tips based on the limited technical data on this
    heater. Disconnecting electrical power and then reconnecting it may
    reset the control. The operating manual appears to indicate that you
    should cycle the selector button to stand by and then back to spa or
    pool to reset the control after an error code is corrected.
    These
    tips may help you determine the cause of the failure. If not, you may
    need to have a repair technician diagnose the failure.
  • Nate Stansfield
    [PDF]
    Hayward Pool and Spa/Hot Tub Heaters - H150FD, H200FD, H250FD ...
    File Format: PDF/Adobe Acrobat - View as HTML
    Automatic reset time ....................................36 ..... Universal H-Series heaters may be compatible with your altitude without modification. ...
    www.haywardnet.com/products/manuals/pdfs/Manual225.pdf - Similar pages -
    More results from www.haywardnet.com »
  • 3,866 Answers
Debris in the unit can cause thi problem, check the unit for debris, then reset the heater also check the thermostat as well hope this hepls you
Posted on Apr 22, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    Well you going to new a tool from a repair place to do that. You can also check it by turning on the heater and sticking a therm. into the water and see if its even getting the temp it says if not the termostat needs to be changed. Sorry I did not recieve your reply until just now fixya is actign up
What should I do if Hayward pool heater is reading error code SF??
The code is SF. This is a teemperature sensor failure. Check the wiring on the electroniics bord and confirm its not damaged and that it is securly plugged in. If all is good than the temperature sensor will need placing.m either a gas fitter or swimming pool reepair center will help with this is your not comfortable replacing it
Jul 15, 2013 | Pool & Spa
Hayward H-Series Not heating water
if all burners are working correctly then put a bypass on heater plumbing open it half way to slow down water flow that will give you a higher heat rise
May 05, 2013 | Hayward H-series Electronic Gas Pool...
Where is the temp sensor on a Hayward H300 ED2 pool heater
take off top there is a copper wired unit going into header and wire to the board
Sep 18, 2012 | Hayward H-series Electronic Gas Pool...
Hayward MILIVOLT H300 BANGING AND POPPING. STILL HEATS BANGING AND POPPING QUITS WHEN HEATING STOPS.
There are two things that can cause this...
low water flow
mineral build up in heat exchanger
Check and verify water flow through the heater
if that is ok, then the heat exchanger needs to be cleaned
heatman101
Sep 25, 2011 | Hayward H-series Electronic Gas Pool...
CODE SF CURRENTLY DISPLAYED ON LED / CLEANED 2 SENSORS ON EXTERNAL PLUMBING,SAME CODE. LOOKING FOR LOCATION OF TEMP.SENSOR?
The code SF indicates there is either a bad temperature sensor or the input to heater is faulty. I would buy a temperature sensor from a pool supply suppilier and install it. That solution has a very high likelihood of being successful. If you have a few tools and a little mechanical ability installation should be easy. I hope this helps
Aug 13, 2011 | Hayward H-series Electronic Gas Pool...
HELP! I have Hayward 400K pool heater. Try to start last weekend and got SF code which is temperature sensor error. What/how I can solve this? Thanks for any help. My email coastalway@yahoo.com
Replace the thermistor. It is a stainless steel plug ~1/2" pipe thread with three wires leading from it to the back of the control panel. Shut the heater down and the pump too; remove it from the header and install a new one. Route the lead wire thru the chassis to the control board and plug it in...problem solved.
John
Jun 16, 2011 | Hayward H-series Electronic Gas Pool...
Haywood heater has code sf what does that mean
SF is a thermistor error. Once the heater cools down it should reset itself. If not, call a service tech.
Jul 03, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
168 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
