Question about Dell Dimension 5100 (D51L1) PC Desktop
Hi-Speed USB I wan't to know how to find which ports are my hi-speed USB ports on my Unit. I have a dimension 5100. Any help?
    Sergeant:
  • 457 Answers
Anyone would surfice
Posted on Sep 23, 2007
SOURCE:
Hi,i am having edimax br-6204 wlg wireless router and i am facing problem sometimes RTD reaches more than 2000ms & getting request timed out in between.I am suspecting WAN port speed is not matching...
Hi best is to choose 100 full duplex you may find this setting in web base router page by typing 192.168.1.1 username admin and password 1234 this is default if you not changed it find WAN setting if there is option you can change it to 100 Full duplex most of the Routers has auto sense features than can do for you should you need any help please contact me http://computernetworksupportindubai.com/
Jul 22, 2011 | Edimax BR-6104 Broadband Router. One...
When uploading pictures from my cameras SD card the computer suggests using a hi-speed USB port. I have tried the other ports and it tells me the same thing. Which port is the High speed? Dell Dimension...
you have no high speed ports installed on your computer. what you have is USB 1.0. you can however purchase a high speed USB pci card (usb 2.0) and install it in your computer to get faster transfer speeds.
Jun 11, 2010 | Dell Dimension 3000 PC Desktop
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Need high speed usb driver
Unfortunately, being that you are using USB 1.1 ports, the high speed 2.0 devices cannot be used. They look the same, but are different hardwares. Even if you hook up a USB 2.0 hub to the USB 1.1 port, you are still stuck with USB 1.1 speed.
Sorry to break the bad news. Let me know if there are any more questions regarding this issue.
Feb 26, 2010 | Dell Latitude C400 (C400GH0E220LH06) PC...
SIIG Hi-speed USB 4-port cardBus - iphone/flashdrive problems
Remove your device from the device manager and reboot unit.
Restart and reload device drivers.
Make sure the driver are for xp pro
Nov 14, 2009 | Electronics - Others
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea? every time i plug a usb in to my computer it comes up that this device can perfom faster on a hi-speed usb port
This is not an error it just means that you are plugging in a usb 2.0 device into a usb 1.0 port. The devise will still function normally just not as fast. You could always add a usb 2.0 pci card to your computer.
May 05, 2008 | Samsung YP-K3 MP3 Player
Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
Dell Dimension 5100 (D51L1) PC Desktop Logo
Ekse
Clive
Clive
