Question about Maytag M6D24E7A Air Conditioner
No control power
What should the primary & secondary voltage be at the transformer? Is it on when the unit is plugged in? The transformer says primary 240v, but it is not...Thank you
  • Anonymous Jun 27, 2008
    unit is pluged in but wont come on, acts as if its unpluged.
  • Anonymous May 04, 2009
    was working fine than just poof..went off....will not start back up
  • 241 Answers
PRIMARY means INPUT(from supply side)
SECONDARY means output( to load side)
Posted on Jan 04, 2008
6ya staff
SOURCE:
Tip
How to measure Voltage in Transforme for Fitness Treadmill
Transformer Test Procedure:1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow
Transformer Test Results :1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and power to the drive board. 2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
Transformer Wire Colors Normal Voltage Value:
Red and Red 110 VAC.
Black and Black 11-13 VAC
White and White 11-13 VAC
Orange and Orange 27-29 VAC
Yellow and Yellow 10-12 VAC
on Oct 26, 2011 | Exercise & Fitness
Tip
How to measure Voltage in Transformer for Fitness Treadmill
Transformer Test Procedure 1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow.
Transformer Test Results:1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and powerto the drive board.2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
ValueRed and Red 110 VAC
.png
ERNESTO CUADRA
MANAGUA, NICARAGUA. C.A.
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 09, 2014 | Intermatic Malibu 300W Power Pack...
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 | Ovens
Hello, I need to replace my furnace control board #HH84AA015. I found the replacement part fairly quickly. Also found a bad transformer,#HTO1BC115 (primary winding indicates 'open' with ohm meter,...
Hello,The transformer (breaks) if the secondary is shorted for any reason.Also a power surge to the house/building will kill it (lighting strike/car hitting telephone pole).It might cause damage to the board.It is cheaper to try a new transformer BUT add a inline 3 amp fuse in the secondary so that will be the last transformer you have to replace(just fuses)if the short is hard to find.Power up the old board & see if it works,unless there is obvious damage.The plug sometimes comes with a new board because there is a wiring change to install it(on some) replacement boards.
Oct 07, 2010 | Heating & Cooling
I'm not getting any low voltage at the t-stat.
Make sure that the transformer has power on the primary side then check the secondary side for low voltage. If you have power on the primary and none on the secondary then replace the transformer.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
Audio video control centre. digatal delayed surronds,model no str-d350z was plugged into wrong voltage,part burned out,can you help
You have not specified the make/model. But if you set is having the transformer as the case may be, and you have plugged into the 220volt with the 120 volt settting, then the transformer would have burned off. If so identify the secondary voltage of the DC cicuit and use a 220volt transformer to replace. If you are not able to identify multiple tappings then you must get the primary of the burned tranformer wound for 220volts. If at all this is aSMPS unit then you will need to replace the full unit as the ratings inthe power will be different.Since you have not specified details of voltage and ratings,I am not able to advice more. Hope you decide. Good day
Jul 23, 2010 | Sony Electronics - Others
Whirlpool MH6151XHT-1 - No Power - Stumped
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Dec 12, 2007 | Whirlpool MH1150XMQ Microwave Oven
Maytag M6D24E7A Air Conditioner Logo
91 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
