Question about Garden
Cuts out and backfires
Troybuilt lawn tractor, 2 years old, courage 19 motor:
Motor cuts out and backfires when warm. Happens when cutting on slope travelling sideways on slope or when going up the slope. Happens with or without load.
After getting back on level with throttle reduced it corrects but will do it again when put against a slope. just started 4 mowings ago.
Plug is dry, black on the sides, and slightly light gray in the middle of the finger.
Carb seems to have fuel flow.
Moving throttle to choke during malfunction only killed the motor.
  • Randy McComas
    Randy McComas May 11, 2010
    Do you have an inline fuel filter?
  • josh1111 May 11, 2010
    could be valves in the engine
    Problem Solver:
  • 10 Answers
Adjust the valves, this should solve the problem,
Posted on Jun 01, 2009
Kholer engine engine repair
remove starter houseing cut old rope out then rewind it till it stops slip new rope through houseing hole and pull hole put a screw driver threw houseing and pulley to make it so it cannot unwind then not the pulley end of rope take a lighter heat knot this will make sure it will not unknot hold rope pull out screw driver pull rope until knott is seat to pully slowly let cord rewind cord until it stops pull out two tune of pully install handle put knot in it and heat the knot with a lighter done cut excess cord off reinstall the red neck let me no if you get have problem like motor dont star or is hard to start
Aug 28, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
My Husqvarna riding mower is just a few years old. It now has problems driving uphill. What would cause the mower to operate normally on flat surfaces, but make it struggle to go gradually up a slig
A hydrostatic transaxle could be low on fluid, or have leaky pump or motor. Check the fluid level. If it is not hydro, check belt from the engine to the transaxle for tightness or slippage.
Dec 19, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
17.5 briggs motor back fired 1 time and now when i engage blades the motor boggs down
The engine is timed internally and externally. Sometimes when it backfires the external timing key where the flywheel and crankshaft join will be damaged enought to put the engine out of time. The engine may run but when put under a load such as cutting grass it will fail. This is about a 30 minute repair and about $2.00 in parts.
Jul 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman LT1000 with a B S 20 hp twin motor. Recently it started backfiring after it runs for about 10 minutes. Only after it's warm it backfires. I changed the oil and filter, plugs,fuel filter...
Carb is running a tad rich and the fuel collects in the muffler. My 20 twin has done it since I bought the thing and that was almost 8 years ago.
Cut the engine idle down before you cut the key off and minimize the bang.
Someone else may give a better explanation of the why but it is just annoying and personally after rebuilding the carb and checking the fuel pump on mine it still does it on occasion. Hasn't hurt a thing on in all these years and I actually thing it blows the soot out of the muffler when it does.
Jun 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Gas will not flow. All hoses and filter have been
that unit has a fule pump on it thay rarley go out but last week i had one that the pump was frozen it was cold here and i took it off and put in the truck and warmed it up i asllso found a lot off water in the gas tank so try that if that dosent fix it than you may need to get a new one let me know and tell me what moter it has and ill tell ya the part number ok i may have one in stock ok
Jan 30, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawn mower
First ncheck for a dirty fuel filter, if its dirty enough it will starve the engine for fuel after a few minutes, then slowly let the fuel system refill as it sits.
Aug 27, 2009 | Garden
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
