Question about Toshiba TN55V71 55" Rear Projection Television
Toshiba TN55V71 55 in. Rear Projection - Damaged
Please advise if the damage the subject tv experienced during a recent move is repairable. The picture is no longer coherent , that is, the different colors do not come close to convergence, probably due to some impact during the move. Is there a way of adjusting this through the controls? The multiple images are off by inches. If I managed to remove the front screen (has me baffled right now) would a physical adjustment do the trick? I have a disappointed family on my hands, please help. Thanks.
  • 372 Answers
Hi. If the convergence is out but uniformly then chances are its not electrical problem more likely to be physical see if the 3 small crt tubes are loose & can move about. Or was your stuff insured during the move if so put in a claim.
Posted on Sep 23, 2007
SOURCE:
Tv comes on fine for a minute or two, but then shuts off for a minute or two, and this cycle repeats.
Check that the post lamp color wheel mirrors or any other moving parts have not been damaged when the lamp blew or that circuitry hasn't been spiked. toshiba rear pro's are well known for shock-wave damage
Nov 08, 2012 | Toshiba 56HM16 Projection Television
Disassemble Toshiba 65H80 tv
No, cabinet is glued and screwed---entire front screen can be removed and the mirror inside also(be very careful with that) as they are the two things that get damaged most when transporting a set.
Moving a long ways or just across town?
Apr 22, 2012 | Toshiba 65H80 65" Rear Projection...
My component inputs dont work on the back of the tv.(red, blue, green) My A/V cables do.(red, white, yellow). Recently moved worked before the move.
most likely you have a damaged small signal board
and it may be able to be repaired localy
or you may have to get a exchange board and reprogram convergence and register adjustment for set to operate according to manufactures specifications
Oct 24, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
When i turn tv on the whole picture is red
This is due to a bad convergence board.
1. install or repair the convergence board.
You will be happy you did the new part would run upwards of $175-200 bucks respectivly the labor is a whole other issue witch I advise if you do not know Tv repair to get estimates at this point. I hope this information finds informative for you please do rate our solutions respetive to the thougt that I am not physically there to see the issue and may need a diffentive answer or secound opinion due that that fact. As your questions are subjective to what is really gone wrong. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 12, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Sep 26, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba rezga 32 " broken
$300-500 replacement cost, installed by a pro, if you find one that doesn't tell you that you can replace the toshiba 720p 32" at a cost of $750(online) or with a toshiba 42" for $999(online). Your call.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black block shape at bottom right corner
Can you post a picture of the issue? Maybe the mirror got damaged or there is
Apr 19, 2007 | Hitachi 60V500 60" Rear Projection...
Toshiba TN55V71 55" Rear Projection Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
