Question about Karcher Garden
My 24o0 pressure washer pump has failed. Unbolted
My Karcher 2400 pressure washer pump has failed. Unbolted the pump but it won't come off from the engine. Spins but acts like it is key locked. WHat is the trick to getting it off?
MW
  • 1tindy Apr 23, 2009
    Thank you for the valuable information. As I continued searching for a solution to my problem I tried the tip of cleaning the buildup of minerals in the unloader. THis is simple to do by removing the silver button on the black plastic cover on the pump. Then remove the two star drive screws and take out the unloader under the spring. If it doesn't come out, hook up the water and start the engine with a towel over the unloader to catch the squirting water and the unloader when it jumps out. Clean off deposits and lubricate piston thorougly with lithium grease. Replaced parts and it worked like new!!!!
    THanks again.
  • 92 Answers
Dear 1tindy,
You asked what the trick is. Well it is a trick, and in fact a big hasle. When a pump has failed it is never removed from the engine or from rhe electric motor(if electric motor driven.). To service the pump only the head and its components must be removed. When these are removed and the oil drained, you see a swash plate that is held down by a bolt. The swah plate could also be fitted by force fitting. After the swash plate there is an oil seal then a bearing. So if for a reason you must remove the pump from the engine you must do all these steps. In a few words....Remove head, remove piston holding head, drain oil, remove swash plate and finally the pump can be pulled away, but with some force,..because there are bearings. I wish to repeat that if the engine has no trouble, do not remove pump from engine. Just service or replace parts of the head of the pump.
Regards,
Fulltech.
Posted on Apr 23, 2009
How do you replace the pressure loading valves
if it is a karcher machine you will need to remove the pump, and the valves need to be removed with a set of valve pullers, karcher sell the special tool needed for this, you cant remove the inset types any other way but with the tool,
any questions just ask away
Feb 24, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
Karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
I have a karcher 2400 psi pressure washer and it doesnt get water pressurized when pulling wand trigger.
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Jun 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Karcher 2400 pressure washer with honda engine. my problem is that i've installed a new rebuild kit in the pressure pump assembly, and now, when i reinstall the assembly back on the engine, i cant even...
Difficult to know from here, check all the screws see if there was a required strenght on some of the screws. You should take it apart and assemble again.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
Gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
May 02, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
332 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
