Question about Dometic Rooftop RV Air Conditioner
My Duo Therm Brisk Aire has a bearing going out on the fan motor. What is the best way to get the motor out? Having trouble getting in to get the squirrel cage off of the motor shaft. Thanks Rick
    President:
  • 2,692 Answers
    Here is what we do:    If possible, we take the whole thing out; motor and fan blades together. Then we sand down the exposed part of the shaft. put penetrating oil on as much as the shaft we can reach. Loosen the set screw(s). If the shaft has a flat on it and you have the room put a cresent wrench on the exposed shaft while moving the squarle cage back and forth. on the shaft, working in the oil.  Put more oil on the shaft and slowly twist it off onto the shaft you have polished with the emery paper.     Baring that working, you still have two options. Take the motor to an electricial motor rrepair place . They can get you a replacment motor usually cheeper that anyone else. Thy likely can also get you the sqirrell cage fan or you can hack saw the shaft from the back(motor) side and take the shaft off that way. This should be a last resort as you may be able to disassemble the motor and Grease the bearings, and place the same motor back into service. I hope this helps.
Posted on May 10, 2009
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm kicking on the compressor, getting cold, but no fan!
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
Mar 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
229 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
