Question about Toshiba 57H83 57" Rear Projection HDTV
Blurry picture I have noticed as of late that the left 1/3 of me screen is out of focus and blurry. Anyone run across this issue and have solution?
    Problem Solver:
  • 10 Answers
Re: Blurry picture
Adjust the flyback focus of your tv
just look at the flyback and you can see there the focus and the adjusting for the screen.
thats only what i know at least maybe it can help =).
Posted on Jan 29, 2008
0 characters
3 Points
Mitsubishi ws-55515 intermitent blurry picture
A bad connection somewhere--when it happens if picture is 3d look in menu for convergence and call up the grid of lines--if they are not perfect you have convergence issue which usually requires parts to be replaced.
In this set sometimes the chips will become flaky and convergence will jump in and out.
May 05, 2012 | Projection Televisions
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Blurry screen?
there are 3 things that will make your tv go blurry, the focus and screen control assembly , the high voltage splitter and the horizotal transformer and that is only if all three tubes are blurry.if only one tube is blurry, more than likely the tube itself is bad.
Aug 05, 2008 | Sony KP-53V80 53" Rear Projection...
Blurred picture
have you tried convergence and magic focus
Dec 31, 2007 | Toshiba 42H81 42" Rear Projection...
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Picture Blurred
If you head a pop then your color wheel may have gone out. You need professional support to get this replaced.
Aug 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 57H83 57" Rear Projection HDTV Logo
103 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
