Question about Ovens
Oven anti-tip bracket
I have been told there was an anti-tip bracket on our frigidaire oven but I don't know where? How is it activated or installed? And if mine doesn't have it where can I get one?
    President:
  • 331 Answers
Hi Jodie,
The anti-tip kits are installed on the floor behind the oven. They're installed BEFORE the oven is moved into place. They are "U"-shaped and when the oven is slid into place, the "U" locks into the back legs of the oven to lock it down.
You can tell if yours is so equipped by simply sliding the oven out away from the wall about 10 inches then looking behind it on the floor. Slide the oven out by opening the door about 5" and place your hands inside... then lift and pull toward you at the same time.
Here is the anti-tip kit for yours... If you see this down there, then you're good to go. If not, order both of those parts (in the previous link) 'cause you'll need them.
Hope this helps!
SG
Posted on Apr 22, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
What size wire should be used from bracket box to oven. Frigidaire , model # FGET2765PBC . What AMP bracket should be used?
I appreciate your post, Steve!
From my understanding you would like to know which wire should be used from the bracket box to your oven for your Frigidaire oven. I have provided you a copy of your installation manual. I am showing that the amp needed for your oven is a 40 amp circuit. I hope that is helpful for you. -Matt
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=FGET2765PBC+&User=&Search=Search
Aug 27, 2015 | Frigidaire Ovens
Bottom oven drop drops down when open
not sure what you mean
but do you have the anti tip bracket installed?
it keeps stove from tipping forward when door is opened
connects to wall and stove leg or adjuster
Jan 03, 2015 | Whirlpool RBD305PD Electric Double Oven
Heating element disconnected
Make sure to keep breaker to oven off because wire could short against back of oven and start a fire. You need to disconnect the tilt bracket and pull the oven out. Replace the clip on the wire if needed. Make sure to reattach tightly. Put it back in the wall, reattaching anti-tip bracket. It should work.
Jun 02, 2014 | GE JRP24 Electric Double Oven
The glass top on my format oven has a crack in it, can i replace the glass top?
Yes it can be replaced and without to much hassle just a few screws. Finding your glass from your manufacturer would be where i would start first, locating the glass is why most people have to purchase a new stove because parts are not available. Please rate my solution it is how i earn my achievements. Thanks in advance
Apr 13, 2012 | Ovens
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
I have a Frigidaire electric oven and flat cooktop that went out. Neither the oven nor the cook top elements heat up. If I turn the element dial slightly, the digital clock lights up (flashes), but...
With the symptoms that you are describing here ...the problem is in the control board... you still have power, but nothing is being told to turn on...the control board controls all of those functions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | Frigidaire Ovens
How to activate the self cleaning mode?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do i remove the bottom element of my frigidaire oven
most frigidair will have 2 screws in the brackets . remove these and pull out slow. and remove wires . do not let the go back in / install the wires on new terminals ( element ) and reset element . install the mounting screws . .. mm
Jul 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
Feb 13, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Ovens Logo
773 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
