Question about SMC Barricade Turbo Router
My router wont hook back to my laptop and i forgot the password
I had my internet last year hooked up to the wireless then we got rid of the internet and we unhooked all are cables and now i got the internet back but my computer wont hook back to the router what do i do
my router is called the smc barricade turbo SMC2404WBR
  • 6 more comments
  • Anonymous Apr 22, 2009
    i did that but it didnt work so i manually reset the the router and i made a new password for the router and it works but now it wont hold a connection?
  • mavric_alpha Apr 22, 2009
    well im getting exelent and and 5 feet
    oh and i did the repair and it didnt work
    well when i set up the router i have internet cable going from my computer to the router and then to the internet plug in the wall then i put this in explorer : http://192.168.2.1/setupw.htm and it will go to the setup wizard it will ask me for a time zone then it will ask rof my connection setting witch is a pppoe and i put my pppoe setting in and password in then it will save the info then it will show me this list: system
    : wan
    : lan
    : wireless
    : nat
    : firewall
    : upnp
    : ddns
    : tools
    oh and status
    when i go to connect to the router it will connect but not to the internet
    how do i change the password on my laptop
    Problem Solver:
  • 14 Answers
Go to your control panle then select network connections, if you see your wireless icon, right click it and try selecting repair first.
Also, if the wireless icon is in the lower right of the monitor, right click it and view wireless networks, look for you router, then select it. Then select connect.
Posted on Apr 22, 2009
  • answer4fix Apr 22, 2009
    I assumne you also updated the new password in your laptop?
    if not do that first.
    Nexrt, do the repair again as mentioned above. What signal strength is the laptop receiving?
    Also, how far away is the router from the laptop?
    Explain what you mean by won't hold a connection? If signal is excellent it should not drop, is the router you are connected to the at the top of the list for preferred connection?? on the view wireless networks preferences of the order of networks to connect to first?
Forgot password to hook up to internet
try resetting the router. press the reset button for couple of seconds. the settings will all return to default. then type your router/modem model in google then look for default password in the internet.
Dec 01, 2013 | Belkin Basic Wireless Router
Wont hook up to a connection for internet i have wireless asking for a password from belalliant
When hooking your wii up to the internet make sure you are connecting to your wireless network that you have set up at home. Make sure you have the correct password that is set up from your router setup. The password is not usually the same password you use to connect to your router via 192.168.1.1 but a different password you set up from within your router settings. You may need to refer to your routers user manual to set this up.
Apr 25, 2011 | Nintendo Wii Console
Need help hooking up wireless (netgear) adaptor 2 bed room computer.We have a linksys router, but forgot password
You will need your password.
Uninstall Internet Programme via Control panel
Hopfully you have the Setup CD.
Insert CD follow online instructions. Recommend you use NI number?
After thought, the Puta in the bedrom, I asume it has wireless adapter?
Dec 26, 2010 | Linksys WRT120N Router
Trying to hook another laptop on to the wireless internet but forgot the passphrase/ key code
if its the default then should be on your router... id you have changed it on the back/side of you router there should be a reset button (very small) need paperclip push it in and should reset to defaults. or from the pc attached type in 192.168.0.1in internet explorer to access set up page and change password
Feb 02, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
I got a wireless router for a new laptop its hooked up but wont let me get online with laptop
check for the default ip setting of wireless router. If it is 192.168.1.1 then you need to change it to 192.168.0.1
to check the ipaddress of the router connect it with wire to laptop. at command prompt type ip config. look for gateway setting.. it will be 192.168.1.1
now go to internet explorer and type the gateway address 192.168.1.1
it will ask you for user name and password
enter admin as username and admin as password
now look for router ip address and change it to 192.168.0.1. save setting and restart the router....do reply back if it works
Nov 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I hook up both a laptop and a desktop to the internet?
Hello;
This is a quick setup for you, depending on the model of router you have. If this is a new router follow these steps
  1. Unplug the power to your Cable or DSL Modem
  2. Take the Ethernet Cable that goes from your modem and plug it in to the WAN or INTERNET port on the back of the router
  3. Plug your Desktop PC in to one of the remaining LAN outlets.
  4. Plug the power to your modem back in and wait 90 seconds
  5. Plug the power to your router in and wait another 90 seconds
  6. On your desktop computer open your browser (Internet Explorer or Firefox) and try one of these websites
  • http://192.168.1.1
  • http://192.168.100.1
  • http://192.168.2.1
  • http://192.168.0.1
  1. You will be prompted for a username and password. Depending on the make and model of router this can vary. This site can help you figure this out: http://www.routerpasswords.com
  2. Once you are in your router you are looking for a Wireless Option. On this tab you will need to set your Network Name or SSID. This will be the name you use to locate your wireless network later.
  3. Next, you will want to look for a wireless security tab. This allows you to setup your security. Options include WEP and WPA encryption. If Available, choose WPA2
  4. Next, it will ask you for a pass phrase or password to protect your wireless connection, this should be tough to guess.
  5. Save all the changes and go to your laptop
  6. On your laptop, beside the time in the bottom corner look for the icon with two monitors.
  7. Right click on the monitors and choose connect to a network
  8. Double click the network you named in step 2. You will be prompted for your password, enter the password you chose in step 4.
That should be it. If you continue to have difficulties please respond with the make and model of wireless router you have and I'll provide you with a more specific help.
Aug 17, 2009 | Computers & Internet
My router apparently needs to be reset/reconfigured i need help??
You may reset the router set the router back to factory default. Username is blank and password will be admin..
Jul 01, 2009 | Linksys WRT54GC Wireless Router
I bought a 2Wire gateway router / modem.
type ur IP address on ur address bar 192.168.1.254
and go to ur firewall and then advanced settings
go to the bottom and allow all application
that should do the trick !
if you cant remember ur system key click forgot password should give you a hint if that dosnt work try still cant remember password
Dec 01, 2008 | 2wire (1000-400108-001) Router
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
SMC Barricade Turbo Router Logo
139 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
