Question about Sanyo Televison & Video
How do I clean the screen to clear finger prints.
I have finger prints on the screen. I need to know how I can remove them.
You need a proper cleaning solution for the new flat panel screen. The best I have tried is Monster ScreenClean. This cleaner comes with a microfiber cloth and actually repels dust and fingerprint buildup. I use it on my big screen and it rarely needs cleaning now.I have used it for three years and works great. Hope this helps.
B.Crowell
Posted on Apr 22, 2009
Paper wont feed 11x17-keeps jamming ( problem with the rollers?)
For first clear rollers w/alcool or orig clearing solvent. If it doesn't solve Your problem remove the rear cover and controll the little fingers hanging in the way of sheet edge. Some of them may be in wrong position because of missing or released spiral. Fix it back with a medical clip or you may remove the whole finger (one piece) if You don't find the spiral. Control and clean the turning surface.
You need strong light in the spot because of the usally black accessories.
Don't miss monthly cleaning procedure.
May 15, 2012 | Canon ImageRUNNER 3235i Black and White...
Tip
I went with this replacement screen when i cracked my original, I've also...
I went with this replacement screen when i cracked my original, I've also replaced my wifes iPhone 5 LCD screen so I've had some experienece.
Right off the bat, you need to take your time when replacing these. Any one thing can go wrong and thats where I feel a majority of the bad reviews for this product stem - people dont know what they're doing, rush it and cut, crimp, bend, or break something.
You will need to remove things from the original screen like the metal backing, clear plastic camera hole, rubber piece for ear slot, wire mesh for ear slot, grounding tape (attached to original screens metal backing), etc. Any decent youtube video will tell you this. If you want your replaced screen done properly, do this. You will need to add a straight edge blade to your tool arsenal, doesnt need to be sharp but a box cutter blade is ideal for working the screen out of the housing (just above the headphone jack is the place to work the blade in between the housing and the screen). Then use the provided plastic tool to work around the edges to fully remove the screen.
I wont lie, even with experience, after putting my new screen in, I had blue lines show up initially, I went back to the screen connections on the motherboard and rechecked them. After loosening the metal plate a bit the screen worked fine. I tightened it way too tight, drive them in so they're snug, not like they're keeping the wheels from falling off your car. You will also need a work area to keep track of all the little pieces, if you have parts left over you did something wrong. Also, when fitting the screen back into the housing, run your fingers down the side touching the screen and housing, with slight force, do not push on the middle of the screen!
What I didnt know - restart your phone after completion to ensure the finger print reader on the home button works! This thing is very sensitive and any loose connection will botch it. Not realizing this and figuring I did something wrong, I spent way more time then i shouldve troubleshooting... All I needed was a fresh phone restart and finger prints worked like a charm. PROVIDED this was my original home button, that was attached to my original motherboard. IF YOURE REPLACING YOUR ORIGINAL HOME BUTTON FINGER PRINT ID WILL NO LONGER WORK!
This apple replacement parts worked like a charm for me, and for $30 thats pretty awesome. Becareful, watch a couple youtube videos, and good luck! Apple IPhone LCD Screen Digitizer Assembly Replacement Parts Wholesale
on Apr 10, 2017 | Electrical Supplies
WHEN I MAKE COPY OR PRINT THE PRINTED PAGE IS NOT CLEAR, IT HAS SOME VERTICAL LINE ON LEFT SIDE AND SOME DOTTS ON RIGHTY SIDE, WHAT SHOULD I DO SOLVE THESE PROBLEM?
For copy jobs, clean the glass with a soft clean cloth, regularly, not just the 8.5 x 11 screen but the 11-inch x .5 inch strip that copies when using the document feeder. Print job: their is probably dirt or ink on the rolling parts. Q-tips are good for cleaning this up, careful, don't burn your fingers.
Mar 27, 2012 | Canon FAX-L400 All-In-One Laser Printer
Hand symbol is coming on the display screen. How to remove it and what does it mean?
it is the finger print on the screen,you shoul use the clear and dry cloth to wape it. and do not wape with strong hammer. should be light and soft waping. do not buy cleaning liquid. it is hamful to the lcd screen
http://www.digitalcamera-parts.net/
www.skiliwah.cn/
e-mail:e-8090team@hotmail.com
Aug 24, 2011 | Canon PowerShot S500 IXUS 500 Digital...
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
Finger print marks on the screen
you mean clean the screen ??
any solution designed to work with perspex or acrylic will be perfect. try "uvex" products or those designed for perspex motorcycle crash helmet visors.
i had a few rear projection tvs over the years and normal everyday household polish didnt do mine any harm at all.
also a damp cloth will remove fingerprints but will leave smears. so skip the washing stage and just use an everday household polish without beeswax in it ,cos that puts a waxy coating on it. stay away from any alchohol based products.and if in doubt try the uvex stuff
http://www.envirosafetyproducts.com/product/Uvex-Clear-Lens-Cleaning-Solution-16-ounce-Pump.html available outside the us as well, made for cleaning safety glasses,
Feb 07, 2010 | JVC HD-61Z575 61" Rear Projection...
How to clean finger prints off screen
You can buy LCD screen wipes they should do the job.
Feb 03, 2010 | Vizio Televison & Video
THERE IS SOME FINGER PR INTS IN OUR LCD MONITOR WANNA ASK HOW YO CLEAN AND REMOVE TNE FINGER PRINT
The best way is to buy a special microfibre cleaning cloth for LCD monitors. Very often the same cloths are used to clean sunglasses so you may already have one of those. Do not use any cleaning liquid. Rub the screen very GENTLY with the cloth until the prints are gone. You can rub fast but remember not to press too hard or you can damage your monitor.
Oct 11, 2009 | Likom HD15A 15" LCD Monitor
Lexmark printer model x1185
I have the same model, and i love it. I know this sounds dumb, but if this is your first refil, did you remove the plastic orange protection tape on cartridge. I know people who forget to do this. If this does not apply....I think your printheads may be clogged with built up ink. You need to manually clean the printhead for colour ink. Use proper cleaning solution and cotton buds, remove colour cartridge, and lay it sideways on paper towel to avoid ink spillage. Now clean down where cartridge sits, until no colour comes out anymore, clean where the cartridge gold part touches the back, but not with solution but with an unscented baby wipe! Now, let it air dry, pick up cartridge careful not to put you fingers on any gold part as oils in our fingers contaminate it. fold a baby wipe in a square, and place ink face on cartridge firmly on it for a few moments. Move it away and you should have 3 little joined boxes of each colour in a neat vertical line. Clear and bright colour, This says cartridge is fine. Replace it as usual. Remeber to reset your ink levels and run alignment if you like. Print a test page to see if it is normal now.
Aug 28, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Televison & Video Logo
98 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
