Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Loud Squeaking noise when feeding paper through.
  • Canon Master
  • 3,866 Answers
You need machine oil to lubercate the feeding rod witch is sold at any hardware store.
Posted on Apr 22, 2009
4 Suggested Answers
  • 7 Answers
SOURCE: HP Laserjet 1020 makes terrible squeaking noise
This may answer you question
Posted on Feb 10, 2010
  • 241 Answers
SOURCE: Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Posted on Jun 08, 2010
  • 12 Answers
SOURCE: Paper will not feed from tray and makes a loud
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
If the rear guide is tight, or even snug, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, you will see calibration marks for the paper size you are using. Unlock the rear paper guide, squeeze the release, and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Posted on Feb 28, 2011
SQUEAKING PRINTER
If it is squeaking when it is trying to pick up the paper then check the Paper Feed system.
If it is squeeking as it tries to print. Then it will be either the Cartridge or the Drum unit.
If it is squeaking from the back of the machine as the page is fed through the fuser then check the fuser is free moving.
Replacing the faulty unit will fix the squeaking. Be that the Paper Feed System/Drum/Toner/Fuser.
Mar 29, 2016 | Brother Office Equipment & Supplies
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
Making loud noise ml1650 printer jam paper feed paper feed problem paper jam
Pull out a paper cassette and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Nov 21, 2010 | Samsung ML1650 Printer
THE ROLLERS THAT FEED PAPER ARE MAKING A LOUD SQUEAKING NOISE. THERE IS NO PAPER JAMMED OR STUCK ANYWHERE. ANYONE ELSE HAVE THIS PROBLEM? AND HOW TO FIX IT.
Wich model of copier or printer you are refering too?
It could be that some clutch or gear is rusted, or some bushings are dirty...
Jul 10, 2010 | Canon Office Equipment & Supplies
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Makes a loud banging noise while the paper will only feed in an inch or so
A bang for a buck. July 25, 2009 8:06 PM RSS feed for this thread .... These paper noise-makers are pretty loud. And you can make them with ... It's just a folded piece of paper so it's pretty inconspicuous. ... more decibles per square inch than about anything else on this list, and hey, they shoot streamers! ...
ask.metafilter.com/128391/A-bang-for-a-buck -
Dec 04, 2009 | Samsung ML 1430 Laser Printer
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
666 people viewed this question
old marine
old marine
