Question about Dell Dimension 4700 PC Desktop
Monitor plug my connects to my monitor is bent
  • Dell Master
  • 3,866 Answers
You can use a sfty pin to carefull bend them back without breaking them is the only solutions I have for you unless your monitor cable can be detached and replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
Emachine E109t6w flashing power button
means it has no signal and/or it is asleep. make sure all your connections are connected properly. if you have unplugged or plugged in the monitor lately make sure you don't have any bent pins on the vga cable.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 12, 2012 | E-Machines eMachines Desktop PC
The screen is yellow sometimes it will go back to normal but only for a few seonds what would cause this?
Hi
Properly due to a bad connection to the monitor, theck the cables, or try another cable.
Mar 13, 2011 | HP Computers & Internet
My monitor is not displaying red color some...
If only ONE colour is missing - it is usually just the VGA connector that is not plugged in properly or you bent a pin while connecting the monitor to the PC.Unplug the VGA cable and look at the pins and make sure nothing is bent .. then re-insert the VGA connector properly. That should fix it.
Good Luck
Feb 04, 2011 | Computers & Internet
My monitor has sound and the little green light is on, but the screen is black no matter what I do. Tried rebooting, checked connections, shined flashlight, etc. I've noticed over the past few days, the...
Make sure it is plugged into the right connector on the back of the pc. If you have intergrated video and a later installed video card make sure it is plugged into the right one. Does the monitor say "no signal"? Have you tried a different monitor to verify that the connection works. Also try a different cable, as the cable could be bad.
Nov 16, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
The color on the monitor suddenly has a blue tint that I am not able to change.
have you removed any of the VGA connectors at all ? - have a look on the plugs for a bent pin - quite a common issue on VGA plugs - that even when bent they will still screw into the socket and depending on which pin you can get a colour shift
Apr 12, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
PC is not working. Monitor message says 'monitor
Check to make sure that you have it plug all the way in to the video card. Also make sure that the video card itself is seated or pushed in good.
You could possibly need a new video card or the pins on the plug coming from the monitor could be bent.
Oct 13, 2009 | Computers & Internet
The monitor is green the color is not
Check the pins out on the monitor and make sure they are straight, even and none of them are bent cause if the cable goes in with bent pins that would cause weird colors to come up on the screen.
Also make sure its connected to the video card properly as well and snug. If that still doesn't fix it, try another known working monitor on the computer and if that works then the lcd is bad on your original monitor, if you still get green even with a new monitor then its a problem with your video card.
Jun 24, 2009 | HP Pavilion F1703 17" LCD Monitor
Will not power on
look at the vga plug to see if there are any pins bent.
If not then you'll need to replace the monitor.
Mark
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
Monitor black
Try looking at the Monitors Plug, Look directly into the Plug, you should see 15 small pins inside the plug.
Sometimes one or two of these pins get bent over and no longer makes contact. If you do see a pin than is not pointing straight out like the reset, the best thing to do is to use a small pair of needle nose pliers to gently straighten the pin. Be very careful becouse once a pin is bent it can break easily.
Oct 18, 2008 | Computers & Internet
Wiring diagramfor w2925
here's a link to emachines' webpage with the user's guide in pdf format to download.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W2925
or download it directly here
http://downloads.emachines.com/userguides/DesktopPC_UserGuide_en.pdf
You must have a PDF reader installed or you can use this snapshot form its Page 19 - PC Desktop Back
The cable from your monitor must connect to the Monitor port (middle and right on picture). Be CAREFULL not to force the connection. The cable only fits one way and you can damage the pins if you force it. If it won't plug in easily, then rotate the plug 180 degrees and try again.
If your connection seems inadequate, you may have bent one of the pins. If you suspect a bent pin, look into the end of the connector on the cable to see if one or more of the gold colored pins are bent. You can straighten the pins yourself with a needle-nosed pliers or a small blade screw driver use gently, otherwise try to get a replacement monitor cable.
Sep 13, 2008 | E-Machines eMachines Desktop PC
Dell Dimension 4700 PC Desktop Logo
22 people viewed this question
Alun Cox
