Question about Panasonic PT-47WX49 47" Rear Projection Television
Projection Tv Problem
I have a 3 year old projection tv. I just started having problems with it last night when it started showing a double image. The red is also way off center. What can I do to fix it?? Please help!!
  • lucb Dec 02, 2007
    I have the same problem. Mine is a PT-56TW53 panasonic rear projection t.v.
    Tried to convergenge it but alas...it doesn't work. The red is all over the place in a wavy pattern.
Had an error occur when I tried emailing, just to make sure, I would like a copy of the service manual for the Panasonic PT-47WX49SE. My email is [email protected] Thank you.
Posted on Oct 08, 2007
Some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at [email protected]
Posted on Oct 03, 2007
SOURCE:
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
This is a problem within the convergence circuit. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | Toshiba 55H70 55" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
The problem you are seeing is a convergence problem. This is a common problem and is fixed either by resoldering bad connections on the convergence ICs or replacing the ICs. These are large black ICs attached to a heatsink and are marked STKxxx. Try resoldering the pins on these ICs first.
Dan
Mar 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Double image on letters for progran guide, 12" green line during perfect focus and on start up componet one need to be re-booted a few times to acquire video
Best advice run as fast as you can to the nearest Repair Shop that does samsung warranty- /// quit calling circuit city it seems like they could care less if your set is fixed or not bad business,first of all those double images you are seeing means you have convergence going out repair cost with out warranty is 350.00 and up to as much as 560.00
Jan 19, 2008 | Samsung HCN529W 52" Rear Projection...
Im seeing double on my 36inch Mitsubishi projection!
Do the colors seem "separated" somehow?  Sounds like the projectors might have become misaligned. Has the TV been knocked by pets/children/spouse?
Nov 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
