WASHER VIBRATES SEVERLY ON SPIN CYCLE. ACTUALLY TRAVELS AROUND UTILITY ROOM
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
There is a switch mounted on the cabinet wall which is supposed to cut out the spin cycle if the load is unbalanced. This switch may be bad. Also, check the suspension. Lift the top, check 4 rods mounted in rubber buffers. One may be loose.
Posted on Apr 22, 2009
Brand new wahse was just installed. The spin cycle vibrates so hard that it moves on the floor and vibrates the whole room. Shipping plug has been removed and washer is level.
Hello. This happened to me, also. We removed the back panel of the washer and removed the styrofoam blocks around the drum. These are for shipping purposes and should have been removed at the time of installation. Hope this helps!
Feb 20, 2011 | Frigidaire GLTF2940ES Front Load Washer
MY WASHER DOES GREAT UNTIL THE SPIN CYCLE, THEN IT GOES CRAZY. IT SPINS SO FAST THAT IT VIBRATES INTO THE MIDDLE OF THE ROOM... ITS ALL I CAN DO TO HOLD IT IN PLACE.. WHAT IS CAUSEING THIS. CAN IT BE...
We picked up a Frigidaire Infinity front loading washing machine. After the first load was washed as it was drying the machine started shaking violently and was moving around the room. We tried a few different things: load sizes, spin speeds, trying to make it even, holding it down, we had no luck. We had skipped removing the shipping hardware. Although it does say IMPORTANT, the importance was placed on keeping them for future use, when shipping, so we figured we could just leave them in. WRONG. They are long bolts! Once we removed them the machine purred during the spin cycle like a little kitten.
Nov 23, 2010 | Frigidaire Affinity ATF7000E Front Load...
On spin cycle machine vibrates and makes a load banging sound especially on the final spin.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Washer vibrates on spin cycle
heatman101
May 05, 2010 | LG WM-2277HW Front Load Washer
Our Kenmore Elite front loader vibrates when it kicks into the high spin cycle. What should we do about this?
if located in upper floor laundry room,you may need to compensate a weak floor by putting an absorption pad under all four legs of the washer...if the dryer next to the washer vibrates when washer is spinning,the floor is the problem,not the washer
Mar 06, 2010 | Washing Machines
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
My washer vibrates so much it actually moves the appliance. Yes, it is level. I also took the clothes out of the washer and tried the spin cycle with out clothes in it and it still vibrates.
If you call LG they actually have some rubber pads to go under the unit to stop it from sliding and it also helps with the vibrations. Part number is 4620ER4002B.
I know of people who have also gotten a thick rubber mat, stal mat, and put it under the unit. They claim that it works wonderfully.
Sgt 48
May 30, 2008 | Maytag Washing Machines
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
