Question about RTO MobiOne Four Wheel Mobility Scooter
Speed dial doesn't work and has come off
The speed dial does not work and has come off. Is there a replacement dial unit I can purchase to replace broken one?
Please give a dealer name or parts store I can purchase for this fix.
My zip code is 11955 Moriches, New York.
thank you for whatever help you can supply.
Peter
  • RTO Master
  • 1,263 Answers
Goto a electronic place like rs or radio spares to get a replacement.
Regards
GeWiz.
Posted on Oct 01, 2009
Have recently been given a Nextra by a friend. however, when switching the machine on it takes forever to work. example ... when i turn the dial to quick wash i have to keep turning the dial off & on...
The fault as seen is with the program timer controller and you might need to replace this unit. The rest of the washer seems to be in good shape and so your washing is perfect. So the timer does not move or contact into the program outputs with the movement.
Try to swap the unit before you invest in one so as to be fully confirmed. Make a note of the connections and double check before this is replaced.
Jul 29, 2011 | Hoover Washing Machines
--2005 GMC Envoy AC Trouble--(compressor still active) Have replaced blower motor (original one had "burn" evidence), resistor and resistor connector. The blower is still not working. Have...
SOUND LIKE BAD BLOWER MOTOR RESISTOR.CHECK BLOWER MOTOR HI BLOW FUSE AND RELAY.YOU WILL NEED OWNERS MANUAL IN GLOVE COMPARTMENT TO LOCATED BLOWER MOTOR FUSES AND RELAYS.
Jun 06, 2011 | GMC Envoy Cars & Trucks
Window AC unit, Hi speed doesn't work. AC motor
It is possible that the high speed went out on the motor but I doubt that. I would replace the switch and see if that takes care of your problem.Good luck and thank you
May 25, 2011 | GE Heating & Cooling
Clicking noise
It sounds like the compatibility dial may be set on the wrong setting. On the base, on the left side, if you're facing it, you will see a dial numbered 1-4. Try turning the dial one number at a time during a call and see if that fixes the clicking. If that doesn't fix it, you might need to do a reset on the unit (CS70 Reset Instructions). Last, you may need to replace the headset. There are replacement headsets available that are refurbished, or whole units that are refurbished with a one year warranty.
Good luck from Headsets Direct!
Feb 22, 2011 | Plantronics CS70 Wireless Headset
How do I open up the dash to get out the ac control unit, dials are not working so I wanted to replace the unit
Wut do u meanthe dials are not working?
U mean the FAN don't work?
If the FAN don't work, its not the panel u have to remove.... its the resistor block that controls the FAN and the SPEED!
Nov 23, 2010 | 2003 Mitsubishi Outlander
Fan blower will not operate on high speed
check the temp control unit ( the dials in your car that let you control the blower speed temp etc) then check your blower motor. i had the same problem and i just needed to replace the control unit because the dials were wearing out.
Sep 16, 2010 | 1996 Chevrolet S-10 Pickup
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
Nokia 1100 speed dial problem
hi,
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
MOTO W755 Speed Dial does not work
SOLUTION: Menu to Setting/Tools to Call Settings to One-Touch Dial: Turn it ON.
Mar 31, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Loud spin, doesn't fill, dial doesn't move.
yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Sep 08, 2007 | Kenmore 43142 Front Load Washer
RTO MobiOne Four Wheel Mobility Scooter Logo
97 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
