What is the easiest way to disconnect throttle and choke cable from the carburetor?
Its kind of annoying but theres a few choices on the throttle theres the tip of the wire get it with some needle nose pliers and pull it out of its seat and some times theres a c clip inside of it and remove it pull the through and then your good and for the choke it has a screw on cap sort of deal put your choke on half choke and and twist the cap thing and pull the choke through. also if the carb is bad and you want to replace it you can also twist off the top cap of the carb and take the needle off ( to do so you must pull the spring up to releive tension and then you push the needle through and once you do that the rest of it is childs play any more questions ask me ) i assumed this is a fan cooled if liquid there are different types of polaris carbs for the liquids i advice you bring it to the dealership because most new polarises have a trouble code thing and if you mess with it it could set it off and you wont beable to drive or it could cause further problems
Where is the drain plug to let out water in the carburetor for a magnum 325 polaris
I started to remove the carburator from my 2004ePolaris Sportsman 700, but ran into thr choke and thotke cables. How do I disconnect them?
how do you remove a choke cable from a Polaris sportsman 600 twin
