Question about Samsung Televison & Video
I recently purchased a samsung le37a456c2d tv and am having a problem storing the channels on dtv mode. they won't save which means everytime i want to watch digitaln tv i have to scan for the channels first...help!
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
SOURCE: Scanning dtv channels
go to menu setup and do the full system reset setup option... Then before you scan for channels make sure it is set to cable... This fixed the problem for me.
Posted on Feb 12, 2009
  • 72 Answers
SOURCE: DTV box hooked up, but doesn't bring in much.
could be a bad antenna or dtv box
Posted on Jun 07, 2009
  • 92 Answers
SOURCE: I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Posted on Jun 20, 2009
My remote Not working,
If your remote is the Samsung one for your TV, it is already programmed. Check to be sure the remote was not stored with batteries in it and try installing new batteries
Jan 08, 2013 | Samsung LE Televison & Video
Ive lost the av channel on my samsung tv; it's
Hello Gem0281; I also have the same problem. Recently my Samsung TV has been acting up, coming on in the night and now the AV channel has vanished!
I have asked spoken to a very technical guy at work called George who has recommended that I connect something, such as DVD, etc. to the back to my TV to see if this helps.
Hope this helps
Oct 28, 2011 | Samsung Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
Ilo 42" Widescreen Plasma TV - Has NO TV
I was told by another tusted repair org. that this brand has to be sent back to Ilo in the original box to them for repair. And that no one has any part parts for this brand.
Sep 26, 2008 | iLO 3200 32 in. LCD Television
Samsung le37a456c2d
For the V+ remote control (Virgin Media have a picture of it here - http://www.virginmedia.com/images/types7-8n.jpg - the code is 0079.
Aug 02, 2008 | Televison & Video
info
menu
mute
power
HTH
Oct 24, 2007 | Televison & Video
Need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Aug 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
173 people viewed this question
Henry  Thomas
Henry Thomas
