Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Replace fork seals they leak - Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
    Scholar:
  • 150 Answers
Take off front wheel..remove fender..remove 10mm long allen in bottom of fork,push tube dust cap up..remove spring around tube ( pry with screw driver) slide tube down hard some times necessary to use pumping action hard. slide off spacers slide down oil seal, replace oil seal then re assemble as you took it off. remove top fork cap install amount of fluid as recommended in the MANUAL THAT I AM SURE YOU HAVE RIGHT?
Posted on Jun 14, 2009
    Problem Solver:
  • 5 Answers
What is your question?
Posted on May 27, 2009
Have a 1999 yamaha r6, right sided a curb to avoid a car, replaced the right fork, but now my left fork is leaking could the impact have dislodged the seal and if so can it be reseated
Hey Ronald... both fork leg seals are leaking..
Let me understand.. you replaced the entire right fork? or just the seal?. The fork legs themselves may be bent .. if the seal is leaking.. it needs to be replaced.. if it is popped loose... then you need to put a new seal in place and probably a new circlip/seal retaining ring and change the fork oil..while you have it apart, I would check the fork leg for warpage(bent)... you need to find a REAL granite SURFACE PLATE..clean it and roll your clean fork on it.. if its bent, it WILL show up..I think if its more than .001" - .0025" warped, then it needs straightening.. a roller press can do it..or replace it..
Sep 04, 2017 | Yamaha Motorcycles
Some hydrolic fluid leak from the left front shock. What & where is this GLT or GLV switch which causes the leak?
Hi Scott:
If I'm understanding correctly, the fork seal is leaking.
Typically the procedure would be to replace the seal, and at the same time make sure that there is no damage to the fork tube assembly that will cause the replacement seal to fail.
I would recommend that you get your local mechanic to either do this for you, or at least coach you through it if you've not done one before.
Jul 18, 2015 | Motorcycles
Fork oil has leaked after compression. Do I need to replace the seal or just top up the oil?
Once it leaks through the fork seals you will need to replace the fork seals.
Apr 29, 2011 | 2004 Yamaha YZ 250
2001 yzf426 front fork leak
Each fork has an outer dust seal, and an inner seal inside of that. Dirt gets between the seal lip and the fork slider and causes the oil to escape. The fix is to have them (Both sides) replaced. You need a fork seal driver tool (Size specific for the size of the fork) and something to measure out the oil amount. It's not an easy job, if you have never done it. Also... if the oil has never been changed, it's due.
Aug 19, 2009 | 2001 Yamaha YZ 426 F
2004 honda shadow 600 VLX leaking fork seal bike has 600 miles on it should I replace left and right if only right is leaking.
check first to see if the leaking fork has any rust pitting on the chrome,if it has and its a very small blemish then fettle it off first,and just replace the leaking seal,as the saying goes..if it aint broke dont fix it,if the seals had been in the forks for years and the bike not used then consider replacing both..
Jun 05, 2009 | 1986 Honda VT 1100 C
Front fork leaking oil from bottom of the seal.
change the oil seals and oil in the fork,and avoid wheelies on the bike and off road biking
May 17, 2009 | 2004 Honda CRF 250 R
Front fork seal is leaking
Yep, drain the fork oil, raise the front wheel in the air, remove the front wheel and axle. The nut to remove the lower leg is at the bottom, hidden by the axle. If it still leaks after seal replacement your fork tubes and lower leg sliders are worn out. Reassemble and remove the top fork cap. Pour in the correct cc of fork oil and ride.
Apr 14, 2009 | Harley Davidson FLHTCUI Electra Glide...
Steering shakes very bad,from 55mph down to 20mph. slowing down
Yes the leak is causing uneven pressure on the front of the bike! The pressure in the left fork is greater then the right fork and will cause shaking of the front end!
Replacing seals and oil to the right fork will fix the shaking!
Hope this helps!
Feb 12, 2009 | 2003 kawasaki ZX-12R
The forks on my bike leak
That the main reason for this type of leak!
replace both seals at once because one new seal will put to much pressure on the other old seal and cause that one to leak soon after you fix the first leak!
Jan 26, 2009 | 2005 Harley Davidson XL 883C Sportster...
Lands Phones Logo
331 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
