Question about Canon PowerShot A80 Digital Camera
Dust or dirt beteen lenses
The camera still operates correctly but there is one spot of dust or dirt in between the lenses which is captured on each photograph when viewed or printed. How can this be removed?
  • Anonymous Dec 09, 2007
    Exacly the same, but more than one spot on the image. my camera stayed in a diusty enveronment for few hours, that's bad.. How is it possible to blow out the dust on the captor ?
    Thanks for your help.
  • 104 Answers
Sir, u try only ur local repairer.and ask clean the CCD
Posted on Mar 24, 2008
I am replacing the bulb in my three year old DLP television. The replacement is straight forward. I wanted to know if there is any preventative maintenance I should do to the mirrors, lenses, or cleaning...
No. Just keep you house clean and vacuum often . Keeping dust and dirt to a minimum is the best way of keeping the fans in the tv from drawing that dust and dirt into the tv. Also cigarette smoke will destroy this type of tv. If you ever get a dark spot in the picture it may be dust on the lense. You can dust the lense with only a microfiber rag.
Aug 30, 2011 | Mitsubishi Televison & Video
Spot that shows up in the same spot on all my pictures
It can be a piece of sticky dust or dirt on sensor surface which can't be removed with a blower or canned air. You can try to remove it by yourself with special cleaning swab and cleaning liquid. But this process requires some experience, so the safer way is to bring camera to service center where sensor can be cleaned fast and risk free.
Jul 19, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Whenever I go to use the camera, in all settings, the f stop just flashes and the camera refuses to take the shot. is there a simple solution or do i need to go to specialist repairers? this happens with a...
This usually means your camera is not communicating with the lens properly. Inside the body of the camera - directly above the opening for the lens mount - are 7 square / rectangular pads. These pads are the electrical contact points, that when mated to the corresponding pins of an automatic Nikon (or compatible) lens, provides the signals to set / confirm f-stop, focus, etc.
Since this is occurring on several lenses, unless you're failing to install the lenses fully into the body, the issue probably lies with the camera body itself. There may be an issue with dust, dirt or oxidation on these contacts - or a problem inside the camera - that is interfering with the those signals. You can wipe these contacts with an alcohol prep pad in an attempt to dislodge any dust and dirt. Clean any lenses used on the camera as well - as dust and dirt on the camera contacts means it's probably been transferred to the lenses, too. Oxidation is a bit trickier to tackle - because the camera is wide open to collecting anything that drops into it. If cleaning with an alcohol prep doesn't solve the problem, I'd contact Nikon support for their suggestions or to arrange for repair.
Jun 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
I got some dots in every pictures i have taken and it's all on the same spot. what are these? is this a pixel problem? can it be fixed?
Not quite enough information for solve.
have you printed these pics and seen the spots?
whayt happens if you print it on a different printer.
Are these dots visible on the preview of the camera?
It could be moisture spot ore dirt inside ofthe camera or even the lense itself Sometimes bacteria will grow inside the lense.
Inspect the lens itself, as well as the mirror insie the camera to see if there is dirt or speck on them.
Please rate our help to keep the FREE sevice online ++++ Thank you for using FIXYA
Sep 07, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
Picture come out with black dot inthe middle of the picture
If Alex's comment didn't resolve your problem, check for dust inside the camera body and on the part of the lens that goes into the camera body. The highlight indicator he speaks of will show on the LCD screen, but should not show up on your final picture once downloaded from the camera. Since the optics on that end of the lens are smaller, they are more susceptible to dust and dirt. If there is dirt or dust inside the camera body and you are not familiar with how to clean it, same yourself some headaches and take it to a qualified camera shop. You can seriously damage the interior optics of your camera by attempting to clean it the wrong way.
May 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
D50 black spot of photos
Ok, step one - find an appropriate cleaning solution - be it an air blower, like a rocket blower, a pads, alcohol and a qtip, etc. Keep in mind that it's not necessarily true more expensive means better cleaning... but I wouldn't go the dirt cheap route of alcohol and a qtip, though many claim they use it. Personally, I use a blower, but I havn't had anything more than dust thus far...
After that, prep a very clean environment, then take off your lens, and clean your mirror!!! Then when you think it's clean, try your camera again... if you still have spots, then you're going to have to clean the sensor... again, I'd use a blower, especially considering that if you ruin the sensor, you've pretty much ruined your entire camera.
If you STILL have spots, check your lens for dust, both front and back lenses. Still spots? Try another lense entirely (might be scratches). STILL on there? Then you probably have a bad sensor... see warranty information and pray :).
If any of this makes you queasy, look in your phonebook for stores that will offer repair, and try to locate the Nikon-qualified if possible.
Oct 05, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Canon 30D spots
It's 99% dust, especially if it appears mostly in smaller apertures (<f/8). To test it, select a small aperture (e.g. f/16) and take a photo of a blue sky. The spots will show consistently on the same location.
They're hard to clean, so chances are you just missed them. Try again, or, better still, send it for cleaning to a professional.
Dec 21, 2007 | Canon EOS 30D Body Only Digital Camera
Spots on Rebel XT image
Dust is something that will need to be addressed. Get a Visual Dust brush and learn how to use it. You can help reduce dust by 1) changing lenses with the camera body facing down and 2) turning off your camera when changing lenses.
Sep 14, 2005 | Canon Digital Rebel XT / EOS 350D Body...
Canon PowerShot A80 Digital Camera Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
