Question about Craftsman Blower Attachment
Craftman leaf blower,not starting,fresh gas,new
Cratman leaf blower,not starting,fresh gas,new plug,checked hoses no cracks exhaust clear,when pressing primerbulb getting gas to crab but none inside,got spark.same problem i was having before i replaced plug and carb and gas
  • 21 Answers
How long has it been sitting with gas in it ,did you have gas stableizer in it ,if not disassemble carb and reinstall it will start right up...lou
Posted on Apr 22, 2009
    Problem Solver:
  • 6 Answers
Don't understand what you meant [ .. but non inside].
Remove the air filter, set the choke full open. The gas stream entering carb can be seen while you press the primebulb.
If not, the fuel line from the primebulb to the carb is not good connection. Either the fuel line is bad air sealed or the primebuld malfunction.
If the unit has got both spark and fuel. You might look into the crankage block for leakage problem [the gasket between the crankage and the cylinder, oil could be seen around this area] The 2 stroke engine use this block keep a mixed fuel before transfer to the cylinder on the next cycle.
Posted on Jun 24, 2009
Homelite 26cc leaf blower got gas,spark,will not start with starting fluid
1 check your comprassion ratio on the cylinder , 2nd fuel hose broken or blocking the fuel 3th or fly whell key broken, start with new spark plug on 2 stroke engine 4th check for exhaust blokage 5th check the switch off and on for shortage, Fit fresh fuel,Check choke for floating the engine.
Jan 30, 2017 | Homelite Garden
Starts but will not run without choke engaged act like its starving for gas
you are right, check your fuel filter, fresh gas and clean your carb out,also check your exhaust screen for being plugged, also a bad fuel cap could cause this, if the cap is not venting
Jul 31, 2011 | Weedeater 25cc Gas Blower ()
I have a shihl br 340 leaf blower it starts but when I make it accelerat bogs down and dies ive tried ajusting the idle screws cleaned the carb not sure what to try next any sugestions
check the muffler for the exhaust being plugged, If not start checking your fuel lines and fresh gas, then fuel filter and ,all esle failes clean carb out.....hope this helps
Apr 25, 2011 | Garden
Craftsman leaf blower starts and then stalls
ckeck fuel filter fuel lines and fresh gas, then clean carb and or rebuild it, also check primer bulb for function hope this helps., check exhaust muffler screen for being plugged
Apr 15, 2011 | Garden
Ran great sat. but would not start sun. same gas changed plug air filter gas soaked with it off still not running tried putting gas in spark plug hole still not running this is a craftmans 2 cycle leaf...
Were you running a fuel mixture of 40:1(3.2 oz of 2 cycle oil to 1 gal of gas), that you mixed up before you started using it again. The unit may have had to much use on Saturday and may be burned up. Try to have a compression test done on the engine, needs to be at least 100 psi to run. If that proves to be good then you can start looking at Fresh gas mixture, a new spark plug, Carburetor rebuild or an ignition module.
HTH
Good Day.
Oct 26, 2009 | Garden
Craftman gas leaf blower stopped working suddenly. I changed the spark plugs but it still won't start
first check for spark, if you have spark gap plug at .030. turn mixture screws completelin give a short squirt of carb cleaner directly into throat of carb and try to start if unit starts then dies ,carb needs to be rebuilt and also change fuel filter in the gastank. gas mixture 40:1
Sep 05, 2009 | Garden
I have a saers craftman 200 blower, installed a new sparkplug. only to have it still not to start.
bad fuel is prob your culprit, drain tank and carb and add fresh 89 octane gas oil mix, check for broken fuel lines and clogged inlet screen inside the carburetor. hope this helps
Mar 11, 2009 | Craftsman Blower Attachment
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
Craftsman Blower Attachment Logo
717 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
