Question about Samsung SGH-E900 Cellular Phone
Changing a ribbon on my samsung e 900
How do i remove housing and how do you open the connecting block to replace the ribbon in anyone knows pleases help
  • 33 Answers
Http://www.excelldirect.com/images/samsunge900gallery/myalbum.html I'm sure you will know how to use this page.There are pictures how to disassembly and assembly E900. If you don't have a soldering iron you can cut off those soldered pieces (even I hate people what do this :) ), but take care about flex cable. Enjoy and take care, mate ;) Level4 tech.
Posted on Sep 26, 2007
SOURCE:
Replacing cracked screen
Insert your plastic pry tool into the seam in the side of your touch and run it along the length of the device to release the back panel from the front.
If your replacement screen did not come with a plastic pry tool, then a small flat-head screwdriver will also work.
Remove the square battery from the motherboard in the front housing by running the pry tool along the sides of it and gently pulling up.
Remove the small piece of black tape from the bottom of the front housing to expose three screws.
Remove the three screws using your small Phillips-head screwdriver. Remove the small screw near the top of the battery connector ribbon as well.
Remove the metal cover from the bottom of the front housing with the plastic pry tool.
This will expose the ribbon that connects the screen to the front housing and motherboard.
Flip the screen-connector ribbon up and gently pop it out. Then remove the two screws at the top of the front housing and disconnect the one other screen-connector ribbon.
This will release a thin metal board at the top of the housing that guards the screen. Pull the metal board out carefully.
Remove the 16 small screws from the side of the screen.
Once the screws are removed, the LCD screen will be free of the housing.
Gently remove the screen and replace it with the new one.
Replace the screws and reassemble the iPod touch the same way you took it apart.
video http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&view=detail&mid=3843F00F64220E3352823843F00F64220E335282&first=0&qpvt=how+to+replace+an+ipod+4g+screen
Nov 05, 2013 | Apple iPod touch
How do I change the optical block in a sony tv
Disconnecting wiring from power supply block
This step may be optional, if power supply block must be transferred to purchased replacement optical block. Undo the blue plastic-coated wire holders to release the two wire bundles. Disconnect the connectors shown with the dotted lines in the photo below. One, which presumably provides power, is disconnected directly from the power supply block, and the other is a regular wire connector.a837b7e.jpg
moz-screenshot-2.pngDisconnecting the optical block fan wires
Disconnect the optical block fan wire connector:
Disconnecting the wiring from the optical block circuit board (C Board)
Carefully pull up on the three wire connectors directly connected to the top of the C Board:
Final wire disconnection from C Board
Remove the screw and gently pull the blue ribbon ribbon cable out of the side of the C Board:
Your optical block should now be entirely free of the TV and ready to ship. I recommend adding specific protection for the projection lens, then sealing the whole unit in a bag to prevent infiltration of dust or packing materials, then carefully packaging it with substantial padding.
Removing the projection lamp (in cases where you are installing a purchased replacement optical block)
Loosen the hex screw next to the projection lamp housing, and pull the lamp and housing outward from the metal clips.
Picture of replacement optical block for KF-60WE610 (courtesy John Setar)
Here is a picture of a replacement optical block for the KF-60WE610. Note that some parts of the old optical block need to be removed and installed on the replacement block.
Jan 25, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Denon DP-29F belt is loose
please not this is when first set up but may help
The drive belt is fitted under the platter. When assembling the
player, please handle the drive belt with care.
• Remove all packing materials attached to the tone arm, except
that on the stylus, and then open the dust cover and assemble.
Remove the stylus cover after assembling.
Hold the platter by the holes at its outer surface, and
then carefully lower the platter so that the center
spindle enters the center hole.
Rotate the platter until one of its outer openings is
aligned with the driving roller. (Refer to illustration.)
Gently grasp and pull at the ribbon tape of the drive
belt that is would under the turntable, and then
extend the belt around the driving roller. (After
attaching, remove the ribbon tape.)
In order to make sure that the drive belt has been
correctly fitted, slowly rotate the platter 3 or 4 turns.
Place the rubber mat on the platter.
IMPORTANT! Please Check.
Check that the drive belt and ribbon tape have been attached
under the platter. Grasp the ribbon tape as shown in the
illustration to the left, and extend it onto the driving roller.
L
R
L
R
L
R
ENGLISH
3 CONNECTIONS
Jul 04, 2009 | Denon DP-29F Turntable
Olivetti lettera 22 replacement black/red ribbon ?
Try Office Depot or one of those big box office supply houses.The Lettera 22 is a pretty old typewriter, but the ribbons ought to be available
Mar 19, 2009 | Olivetti Lettera 25 Typewriter
How do I replace the thermostat in my 1990 buick LeSabre?
Hello thank you for using FixYa.com for your answer my name is David .
This should help you out if you have any other questions please let me know.
  • Drain some coolant into a clean container until the coolant level is below the thermostat housing.
  • Remove the upper radiator hose connection from the thermostat housing.
  • Loosen the housing bolts and remove the housing.
  • Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If the gasket remains on either of the surfaces, there will probably bea coolant leak after reassembly. Some engines use a rubber O-ring to seal a thermostat housing.
  • Compare the size of the thermostat to the old one. They are of different sizes, types, and temperature ratings.
  • The temperature rating is stamped on the sensing bulb on the bottom of the thermostat. The temperature bulb faces the block.
  • When replacing a thermostat, be sure that the thermostat fits into the groove in the block or outlet housing. If the thermostat is installed upside down, the engine will overheat.
  • Install the gasket.
  • Reinstall the thermostat housing. Refill the system and run the engine or pressure test to check for leaks.
  • When the engine has reached operating temperature make sure the thermostat opens.
  • You should be able to see coolant circulating within the radiator.
  • Another way of checking thermostat operation is to feel the top of the radiator hose or use a thermometer or multimeter with a temperature probe to confirm that the coolant is warming up.
  • If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stuck closed and must be replaced.
Nov 08, 2008 | 1990 Buick LeSabre
Nintendo DS Lite bottem screen is white.
hi their is only i thing you can try yourself as if it is anything else it probably requires soldering and new parts.
on the bottom screen their will be a ribbon its really thin and will clip onto the board from the screen the same with the top one the only thing you can do yourself is check that the ribbon hasnt come out of the housing and is causing a bad conection it might have a sticky bit of thin tape over the conector this holds the ribbon in and prevents it from moving out of the connector you will need to check both ends of this.
try pushing the ribbon back into the conector without removing the tape and see if this solves the problem.
If you can see the clips holding the ribbon into the connector you can undo these should just clip open the remove the ribbon and put it back in again the push clips back to lock position.
If this dont solve your problem then the chances are you need the screen replacing but your problem is the same with mobile phoned and removing the ribbon and putting it back in again usually solves this problem let me know how you get on ok
Dec 29, 2007 | Nintendo DS Lite Console
Scratched audiovox screen
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. The outer scratched screen is the touch screen.
Ebay, and various online retailers have them for around $40. You can do it yourself if you try.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Dec 07, 2007 | Audiovox PPC 6700
CASIO E-125 no backlit
Usually the ribbon cable connection that powers the backlight is the problem.If you remove the four screws in the back and take off the back cover. (note that there are two tabs on both sides of the cover half way up)You can see the white ribbon cable on the left above the battery back housing. Gently wiggle it and see if the backlight goes on. The cable is attached with a small brown insert that holds it in. It is removable so you might be able to get an electronics shop to replace the cable connection or the cable itself.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Samsung SGH-E900 Cellular Phone Logo
263 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
