Question about Pentax ZX-7 35mm SLR Camera
Shutter stuck halfway through cycle. Curtain
Shutter stuck halfway through cycle. Curtain closed, mirror stuck "up". Camera will not "light up" and electric motor runs internally all of the time unless you remove the batteries. Can it be "unstuck" in the field? This is a Pentax ZX-7 that has had less than 20 rolls of filme through it. I can't imagine that it is worn out already!
Ostewart2102
  • 41 Answers
SOURCE: Mirror locked up
Older cameras like this are notorious for locking up after not being used for quite some time. Though, it is an easy fix, it does require some steady hands and a good memory of where everything was after you're taken it out or apart. The best solution for this is, once you've taken it apart and have access to the mirror, is to have a q-tip with a little vasoline on the tip, apply a thin (very thin) layer along all springs and joints surround the mirror and around the edges of the mirror opening, while avoiding getting any vasoline on the mirror itself. I've worked with cameras all my life and have worked at camera shops, and what I've explained here is exactly what a camera repair place would do. But, if you don't feel comfortable with small parts and tiny screws, a camera shop will gladly fix it for you, and not at a bad price.
So, Good luck! Hope this helps. I hope you're out taking photos soon!
Olivia~*
Posted on Dec 01, 2008
  • 11967 Answers
SOURCE: can the shutter curtain be replaced on a Pentax
It can be replaced only by a trained service technician. Check the Pentax website for a service center near you.
Posted on Aug 12, 2009
SOURCE: pentax me super can not advance the film advance
all that was wrong with mine- THANK GOD is that the shutter was a little sticky! so i fixed it myself! yeah for me!
i thought it was really broken! but thanks to fixya.com i can actually FIX things instead of BREAKING them more! hahaha
thanks- this site is a LIFE SAVER!
Posted on Sep 25, 2009
  • 411 Answers
SOURCE: THE SHUTTER STUCK OPEN AND NOTHING HAPPENS, EXCEPT
loader gear broken,get it replaced ,get it done by a camera tec.
Posted on Mar 08, 2010
miket756
  • 2702 Answers
SOURCE: The shutter on my Pentax zx-50 SLR is stuck in the
if its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
Posted on Nov 28, 2010
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
I have a minolta x-300s film camera, the diaphragm control lever ( the lever at the bottom when the lense is removed that controls the mirror) is stuck to the left (meaning the mirror is up or away) when i...
Try this before spending money on anything:
Open the camera front and back: ie, take off the lens, open the back door.
With clean hands, put fingers in from both front and back.
VERY GENTLY slide the shutter curtain to the side, as it would do if the shutter release was working.
In my case, when I let go of the curtain, the whole situation resolved itself, the mirror went back up into position and the winder and release both started working again.
Thanks to DF on photonet for this tip: http://photo.net/sony-minolta-slr-system-forum/00X5Nn
May 25, 2011 | Konica Minolta X300 35mm Film Camera
Shutter won't open/blaack when you look through lens
Your shutter may be stuck open... this will give the appearance of the shutter not opening as well as no image when you look through the viewfinder.
Open the back of the camera, as if you were replacing the film, and look to see if the shutter is open. If it is, you can probably see light coming through the lens when looking from the back of the camera.
If this is the case, you will need to find out why the shutter is stuck open.
Some cameras use a battery to activate the shutter, some cameras have a "bulb" setting that keeps the shutter open for long exposures.
Whatever you do, do NOT force the shutter... I might jiggle it a little bit to see if it will close, but I wouldn't recommend more than a slight jiggle.
While you have camera open, inspect the mirror. If the shutter is closed but the mirror is stuck "up" (to allow light to reach the shutter/firm), there is a chance that you would not be able to activate the shutter.
Aug 31, 2010 | Pentax Program Plus 35mm SLR Camera
The shutter is stuck...all I see is black
Your second curtain is not releasing the mirror to come down.
This happens with weak 2nd shutter curtain tension.
If the wind lever is stuck and the mirror does not come down then the mirror tension spring came off.
May 12, 2010 | Pentax K1000 35mm SLR Camera
Shutter curtain dont reset mirror in certain speeds
wwinters81
your K1000 needs a clean, lube and adjust. ( CLA ) the shutter must be repaired and calibrated. not a hard job, but a special calibration instrument must be used to calibrate all shutter speeds.
slamming the camera just makes things worse, you could brake the meter. take or send your K1000 to a camera repair shop and get an estimate for a CLA.
there are no new parts available, so if the camera requires parts the shop should state good used parts only.
Mar 12, 2009 | Pentax K1000 35mm SLR Camera
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Mirror lockup for minolta XG-1
Sounds like the shutter lubrication has dried out causing the closing curtain to stick. DO NOT try spraying an oil into the camera to try and fix this, it will cause more problems and could destroy the circuit board. I would recommend sending the camera to a shop specializing in the overhaul of older cameras. You might try www.united-camera.com They have been repairing cameras since the fifties and still repair the XG series cameras
Dec 11, 2008 | Minolta Maxxum 50 QD 35mm SLR Camera
Mirror lock up
carefully push the shutter curtain to the rewind side. If you look at the camera from the front with the lens off, push the cloth curtain to the right
Jul 28, 2008 | Konica Minolta Photography
Pentax ZX-7 35mm SLR Camera Logo
109 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
