Question about Car Audio & Video
Cd would not eject now wont play or eject or anything.
I have a alpine 6cd player stereo in my lincoln LS when i tried to eject it wouldn't eject. now it wont do anything. How can i get a disk out?
    Problem Solver:
  • 13 Answers
Start by checking all of the fuses in your car if the radio is not even powering on. If this does not work your next step is to have the unit repaired or replaced at which point the cds can by removed by taking the unit apart. You can do this yourself or take it to a best buy and have it replace with an aftermarket unit which will be much better and a lot cheaper than going back to the dealer
Posted on Apr 23, 2009
Cd in02 lincoln ls light comes on ( cd error ) wont work or eject ??
This can be from a couple things that caused this. Most the time and 99% of the time that causes this is the cd driver is dirty, which some times it just spits it out after error message comes on. AND in your case, it is staying in there spinning and reading error, and won't eject. One way that is possible to have this kick out is, to unhook battery, wait 5 minutes, and re- hook battery up, and sometimes it will trigger it to eject. If not, you do not want to start forcing something in there, it could cause more damage. You would then, i suggest , take it to car stereo shop as they have all kinds of methods to check it out and eject cd and figure out the fix method. Which could be as simple as a good cleaning, or cd itself was bad, or mechanism is screwed up.
I hope this helps Mike.
Oct 23, 2011 | 2002 Lincoln LS
My Alpine cd receiver CDA 7837 wont play any music discs i burn. ive tried using nero which automatically converts them to cda but it wont play them it just ejects the disc. it works when i put it in my...
You may want to try a different brand of blank cds. I had an alpine that would not play sony white label cds, but played most everything else.
Aug 30, 2011 | Alpine CDM-7833
Need to eject Alpine Renault 6CD changer cartidge- no power?
lok at the 8 pin plug the first pin from the left is the power wire and the round metal part of the plug is the ground
good luck
the last pin on the right is the ignition
Mar 21, 2010 | Alpine CHM-S630 6-Disc CD Changer
It won't wont eject or play cd's
Hi.
Try pressin repeatedly the eject button on the on dash player while at the same time you start the stereo.
If that does not work you can try disconnecting the car battery to reset the unit, and then attempt again the procedure above.
Remember that you may be asked stereo code after disconnecting battery, have it ready.
If still no luck, then the unit must be removed from the dash to be taken apart, so to remove the stuck disk.
Regards.
PS: Here the procedure above illustrated in detail. The procedure is described for home DVD players, but it is the same on any optical unit. Naturally , since the unit is an in-car system, you do not have power cord, but you will need to disconnect battery to reset the system: player system won't eject disk.
Mar 14, 2010 | Alpine Car Audio & Video
Stuck cd
press & hold the eject button
Feb 07, 2009 | Alpine CDA-7863 CD Player
2001 Lincoln LS Can't get the CDs to eject
my problem is with the alpine system. it only ejects when cold. if tried when hot it jams and wont play cds or release until cold again. i removed the panel above the radio and place an icepac on the radio and after a while it starts spitting out cds
Jul 22, 2008 | Panasonic CQ-DPX33 CD Changer
2003 Lincoln LS
that's a mechanical issue, actually...i'm assuming the rest of the cd player is working?
Feb 29, 2008 | Car Audio & Video
2003 Lincoln LS
My 2001 Lincoln LS has done this 3 or 4 times in the last 8 years. I disconnected the battery (for a minute), pulled the fuse, held the 'load' 'eject' button simultaneously for about 1 minute, banged on the dash, slid a credit card along the opening...prayed : ) For 2 days it wouldn't work. Then today I pressed the CD button and it worked. I immediately removed the one 'burned' CD that I had in slot 5, The only think I can think might have affected it was-
1. Put in a new CD that one of our local gospel groups made.
2. Weather had been quite warm, then 2 days ago, it got freezing cold outside again????
I don't know? Probably just an idiopathic occurrence.
It is the Alpine head, LS sports package.
Oct 18, 2007 | Car Audio & Video
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
