I have a Foxconn 755/760A01 motherboard. The problem i have is that quite often the monitor screen goes black and the mouse goes off although i can still put the caps lock and num lock buttons on and off. This keeps happening several times a night, sometimes far more frequent, sometimes as going into windows xp or can be when playing online in a game. any ideas?
  • nickhannagan Apr 23, 2009
    Hi
    Thx for the advice. As for garphics drivers, the latest ati drivers i use tend to cause more problems than they are worth. I had to download a special ati catalyst center and driver as mine is an agp card. This is a newish card, but i had this problem before. I tend to think maybe its a faulty motherboard as its very un-regular problem. Sometimes it can happen just on bootup, sometimes my pc can go for ages without this problem occuring, but it happens atleast several times a night.
  • 433 Answers
This sounds like your video drivers are corrupted.
Find the newest drivers and install them. ATI, nVidia or Foxconn sites will have the latest drivers. If that doesn't help look for a possible heat event...check the log in the BIOS. If you have a mainboard that has heat protection monitoring, check the settings. Clean out the CPU fan and the heat sync...with Blow Off canned air...Hope this helps you...good luck
Posted on Apr 23, 2009
Mouse can not move
make sure the lead is securely seated or the batteries have charge and are secure also the usb device is secure in the usb port or you could restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
if you need any further help with this post a reply
hope this helps
Aug 03, 2011 | Foxconn 661MX Motherboard
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
My system turns on but the monitor shows a black screen and my mouse does not react what may be the problem? Many Thanks!
Your system may be powering on, but it's not starting up. This might be due to the power supply, memory or system board. Start by making sure your memory modules are firmly seated and latched into their sockets. Then substitute a known good power supply to make sure that's not the issue. Finally suspect the mother board. A system that doesn't start is a common problem when the board is bad.
May 18, 2009 | Foxconn Computers & Internet
Freezing or Jumping Mouse Pointer
This could happen if the PS/2 connector on the motherboard is defective, or if there is a failing component in the PS/2 circuitry on the motherboard.
Could also be due to loose solder points at the PS/2 connector.
This needs to be checked by a qualified technician.
Apr 12, 2009 | Foxconn 661MX Motherboard (FOX661MXMB)
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Foxconn 600A01-6LRS FANS START BUT NOTHING ON screen
Does your video card suit the motherboard they have different ratings
2X 4X 8X 16X if yours is a 16X and you fit to any lower number it will not work this is for both AGP and PCI-E
Aug 09, 2008 | Foxconn MB KT600 600A01-6LRS Motherboard
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
1yr computer, windows XP foxconn motherboard. Screen went black, then just the foxconn name, and directions on the bottom to press del for set up, tab, or esc. Mouse doesnt respond.
Maybe the bios of your motherboard is not working well you need to replace the cmos battery 3.6v lithium battery it the same some watch battery.
Apr 25, 2008 | Computers & Internet
Acer al1914-monitor goes black
Have you checked the settings in your screen-saver and power options in the display control panel?
Dec 21, 2007 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
