Question about Karcher 2500 PSI Pressure Washer
There is no power when you use the sprayer Karcher K2.89
Water comes out just fine water there is no pressure
  • Anonymous Apr 27, 2009
    no high pressure
  • susie5416 May 05, 2009
    It's the K-2.89 I know this sounds dumb , but what do you mean by the end hose comes off? How would you know if it is the pump, it still makes a noise when it comes on! Because water goes in where the hose connects to the machine. If I take it apart is it easy to install and take of fthe old pump?
  • 226 Answers
Depends on the model, but it is probably the pump, Most Karchers do not use expensive pumps. Also, if the end of your hose is off, you won't get much pressure either as it takes a restriction in the end of the hose to increase the pressure. I have commercial pressure washing business & occasionally have an hose end come off, pump problem or high pressure switch problem, but all this stuff can be fixed. Hope this helps you, Rick
Posted on Apr 26, 2009
Water will not come out of sprayer
either the checkvalves closed on the inlet or the chemical injector on the output may be clogged they will have to be removed for inspection.
Jul 31, 2013 | Karcher G 2600 VH Gas Pressure Washer
Making a shuddering noise and cant seem to get full power
Make sure screen where hose attaches is clean for proper water flow to sprayer, make sure you have good flow from hose supplying water to sprayer. Turn water supply on, and hold handle down to spray, before turning on and see if it helps.
Jul 14, 2011 | Karcher Garden
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
I have a pressure washer that sputer when i pull the trigger. The moter sounds fine but i have pressure then nothing and i have pressure. Thank you Stu
how do i unclog the end of my pressure sprayer it works on low pressure but when i put it on high pressure nothing comes no water comes out.
May 03, 2011 | Karcher 2500 PSI Pressure Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
May 25, 2009 | McCulloch MCCFH180B Electric Pressure...
My Karcher high pressure sprayer is delivering intermitant pressure.Every 15 seconds or so it developes high pressure for only about two seconds. Why is it not delivering a constant high pressure stream?
Check that the water supply is constant , it sounds like the pump might be pushing out more water than can be delivered , or it could be a dirty inlet filter
May 17, 2009 | Karcher PSI Electric Pressure Washer
Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Oct 09, 2008 | Karcher K DS 5500 Vacuum
Karcher 2500 PSI Pressure Washer Logo
752 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
