Question about HP Office Equipment & Supplies
The fax How do I get the fax to run what all will I need to have?
  • 21 Answers
Software available thru google..
Posted on Apr 22, 2009
My printer will not fax says not connected to network when it is.
faxing requires some type of Phone connection in most instances, network faxing is another set of drivers that need to run on your PC, the same as phone line faxing that utilizes your modem (as long as the modem is fax capable) the issue you have is the way it is set up. first off you have to have the communications between the printer and the computer running properly. If you do not have a router with a wifi connection and the printer is connecting directly to the computer wirelessly, you need to make sure it is set for peer to peer networking, if you have a true network using a router and wifi (more than one computer can connect to it, you need to make sure you are set for that. Remember, you are not faxing from the printer if it is not connected to a phone line, you are faxing from your computer. and you need to make sure you are running the correct type of fax software, for network faxing or dial up (phone line) faxing.
Jan 21, 2015 | HP Photosmart 7510 e-All-in-One -...
Cannot install fax
More information is needed. What type of fax machine, how are you trying to hook it up, does it run off a computer or a stand alone? All it says is cannot install fax.
Jan 12, 2015 | Office Equipment & Supplies
Why am I unable to send a fax?
Are you running ADSL on your fax phone line ? Will need an ADSL line Splitter with fax plugged into phone side of splitter. Could also be plugged into a PBX extension then you need to convert analogue to digital for PBX.
Sep 08, 2014 | Office Equipment & Supplies
How to run a report on a fax machine?
To run the auto dial and speed dial report you need to do the following:
Press Menu, 5, 2, then Start. The display will prompt you to the correct numbers. This will give you a list of pre-programmed numbers.
Jul 15, 2014 | Brother MFC-8220 Fax
I keep getting error message 388 whenever I fax to any number. I have been able to receive faxes. My all in one is an HP officejet pro L7580
You probably need to run the fax test to check if the fax mechanism is working fine.
Click on Setup Button ( ranch like symbol ) on the printer front panel.
Scroll down till you find Tools ( press ok )
Check for Run Fax Test ( Press OK )
It will print the test results and everything should pass.
To solve your fax issue, follow the steps below.
Check for Advanced Fax Setup ( or Basic Fax Setup ) - Press OK
Look for ECM ( Error correction mode ) - Press OK
Turn the ECM OFF
Try to send fax. It Should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 16, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Black vertical lines on transmitted faxes.
Just go to menu and then in tools...run alignment and clean them....
Jun 29, 2010 | HP 1040 Plain Paper Inkjet Fax
Fax running slow
try unplugging machine. then press and hold "stop/exit" button while plugging in machine. continue holding button for 5 secs, then release. that is a procedure to clear any faxes stuck in memory.
hth,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
Can't fax
Fax machines will not work on digital phone lines. You need to have a seperate phone line to run one. If your office is using DSL for internet, usually they can run one off of that line with a filter installed.
Jul 12, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
NetoDragon voice-fax 56k modem - i need a driver for this
I need a driver for my NetoDragon 56k modem fax & voice. My computer was redone and the dingbat I took it to didn't even load in my drivers for fax or my fax talk communicator program which i had asked him to do. (unfortunately my regular computer guy is out of the country until..
Dec 16, 2007 | Neto Dragon FM56-V92 Modem
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
