Question about Garmin nuvi 205W GPS Receiver
GArmin 205W won't turn back on
My GPS was working fine. I had just turned it back on in the car and then it shut off and will not turn on. There is no reset button. I held it in the on position for 8 seconds and that did not work either. Help.
Thanks.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    There is a reset located on the bottom where the decal is. Use the tip of a pen to push it.
    - Jim
    SHARCNET-USA
I recently ran into the same problem, my 205w would not power back on. I logged in Garmin website under repair solutions. Said hit reset button using pen or stylis. My 205w does not have a
reset button....further comments in the reset instructions said if your device does not a button,
slide on switch to the left and hold 10 to 15 seconds it should power on while your holding it.
it took 12 seconds for me... This was refered to as a soft reset
Hope this helps, Enjoy!
Posted on Apr 23, 2009
  • Arni Tecson Oct 07, 2011
    This helped a lot!! My GPS is back!!!
    Problem Solver:
  • 8 Answers
This model DOES have a reset button as I have the same model. It's located on the bottom decal with all the writing. It is a bullseye that says "reset." I once had this problem but a recent software upgrade fixed it. If you download "webupdater" from garmin and hookup your unit, you'll get the new upgrade.
Posted on Jun 18, 2009
  • 469 Answers
Could it be the battery is dead? Check the fuse for the cigarette lighter socket.
Check the fuse in the cigarette lighter adapter on your power cord, the tip should twist off to expose a fuse.
Hope this is of some help.
Ed
Posted on Apr 22, 2009
How do you reset a navigon 2090s
  • Two ways to reset your GPS.
  1. Take a pen or a stylus and press the reset button in the upper right side of the GPS. The GPS will shut down and then you can use the power on button to turn the unit back on.
  2. If you want to do a hard reset and go back to the factory defaults then go to Options > Settings > Options > Factory Settings. This will wipe anything you have stored in your GPS.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 11, 2011 | Navigon 2090S Car GPS Receiver
My gps unit got stuck on a location and I turned it off and it won't turn back on I've held the power button down for a while but nothing
Look in the back of the unit for a reset button, this will be a small tiny button or maybe a small hole in the back with the word reset on it. If it is the hole then use a paper clip to to push the reset button. Note power must be on to reset the unit.
Jan 14, 2010 | Panasonic Navigon 5100
GPS INSTRUCTIONS
this may sound silly but your reset button may be stuck on on.
try resseting everything and updating the device.
Jul 01, 2009 | GPS
Garmin froze and after turned off now will not turn back on
Pull the trim ring off the front of the GPS and you will find a reset button. Press thia button and hold it down and start the GPS It will reset and you should be fine.
Thanks for using Fixya.com
Harleyknut.
Apr 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
Feb 11, 2009 | Tomtom GO 910 GPS Receiver
No signal
Turn the unit off
Pry off the silver faceplate and locate the reset button underneath
Hold the reset button down for 30 seconds then turn on the GPS while holding the button down.
Once the GPS screen activates you can release the reset button.
If this doesn't solve the problem your next step would be to download the latest software update from this link: www.garmin.com
Jan 07, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin does not turn on
Turn the on button at the top of the device o by pushing it to the left and hold in that position for at least 20 seconds. The device will reset and turn on. This has worked several times for me when the 780 has refused to turn on.
Nov 18, 2008 | GPS
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
GARMIN 340 SHUTS OFF, LIKE BATTERY IS DEAD,WILL ONLY WORK ON CHARGER.IF YOUSHUT IT OFF IT WILL NOT TURN ON
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Feb 27, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
5,017 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
