Question about Sanyo DS32224 TV
My Sanyo DS32225 worked fine for about 20 hrs.,then NO Picture at all. The sound works fine and it will change channels but not even the menu will come up on screen. Whats up?
    Sergeant:
    Champion:
  • 318 Answers
They are two things to check, the power supply has a voltage of 90-110volts which triggers a line transformer to oscillate,
firstly check that voltage if that voltage is there then check the line transistor.
Posted on Apr 24, 2009
46' Sanyo DP4684 MYSTERY
Sounds like maybe whatever box or source is providing signal is your problem.
Mar 11, 2012 | Sanyo Televison & Video
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
Sound problem
when you mail me,i have an service manual for you
haas1@kabelfoon.nl
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Jul 01, 2009 | Philips 32PW6506 32" TV
Technosonic stb2009 working fine until last night when the picture froze and the sound went off. Changed channels only to find that all channels are blank, did a reinstall only to be told to check my...
It seemed to sort itself out. I switched it off for 24 hrs and then the following evening switched it back on and hey presto it was working again, haven't a clue how it did it but it did
Aug 12, 2008 | Televison & Video
DS20930 TV
Sanyo makes a fine TV. You have a problem in the vertical circuit causing the line. You should not play the set in that condition because you can dammage the picture tube. Call a few local shops to get an idea of what they charge to fix a vertical problem on a 20" TV. If the cost of repair exceeds about 65% of replacement, toss it. In my opinion the newer sets are lacking in quality compared to older ones. In short , they break more often. If you choose to buy a new TV stay with a known Japanese brand.
Nov 29, 2007 | Sanyo DS20930 20" TV
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sanyo DS32224 TV Logo
145 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
