Question about Whirlpool MH2155XPS Microwave Oven
Exhaust Doesn't Work
The exhaust doesn't pull or draw from bottom.
  • spruce Nov 02, 2007
    The exhaust doesn't work. The fan blows plenty of air out of the back of the microwave (into the ventilation duct) but it doesn't pull air from the bottom (remove smoke from stove). I removed the microwave filters and had the same results.
  • Anonymous Feb 02, 2008
    brand new no nest
  • Whirlpool Master
  • 9,098 Answers
Do you hear the exhaust fan running? If so, then the grease filter may be clogged, or the exahust ducts from the oven to the outdoors may be blocked. Sometimes there will be an animal nest inside the duct near the outside wall. If the fan is not running, you may have a problem with the exhaust fan or with the control circuit board, which we repair for $39.95 nationwide. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: If you still have questions, please feel free to follow up here or by e-mail. We appreciate your thoughtful ratings to our reply.
Posted on Sep 28, 2007
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
Microwave exhaust fan doesn't really exhause any steam out. Model 721.80042700
The fan is for cooling the magnetron, nothing else. Steam remains in the cavity which is why the door should be left open after cooking to allow the steam to evaporate.
May 30, 2017 | Kenmore 30" Microwave Combination...
Ge spacemakerxl microwave jvm1650 vent is not drawing air
It is possible, you have removed and checked the filters, still the intake is low even without the protective filters. The system will need to be taken apart to find the opstruction, or as you said a hole in the venting mechanism.
Jul 04, 2012 | GE JVM1650 1000 Watts Microwave Oven
How does this microwave exhaust system work. The installer did not use any duct work, so is the exhaust internal somehow? There is no grill on the exterior for exhaust
The exhaust fan appears to intake through a louvered vent in the bottom rear of the microwave case and output through a grease filter near the top front center of the case. You may be able to see some vent holes along the top of the case though these might be obscured by the manner in which the microwave was installed. You should be able to pop off the front panel that runs above the door but you'll need to consult the owners manual for specific instuctions.
Apr 08, 2011 | Bosch HMV9305 Microwave Oven
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Need the exhaust fan to blow out the back instead of the front
I believe the box on top (plenum) has screws in it, and can be rotated.
Aug 05, 2009 | Kenmore Microwave Ovens
JVM1790 Microwave GE-Draws air from bottom and top vents
1. You have to have exhaust pipe to connect m/w vent and this pipe has to be free from obstruction.
2. If it already connected and good, but air come from vent bar over door, then blow motor on top of the m/w was installed in wrong position ( motor has 2 -3 position depends which way air coming out up, back or front).
3. In this case you have to remove m/w from installation and change motor position.
Dec 10, 2008 | GE JVM1490 Convection/Microwave Oven
Exhaust fan draws poorly
put a bomb on it and tic tic tic boooooooooooooommmmmmmmmm
and buy a new one!
May 23, 2008 | KitchenAid KHMS147 Microwave Oven
Microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Whirlpool MH2155XPS Microwave Oven Logo
163 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
