Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Sandisk Cruzer Micro 8GB USB Flash Drive, destroying files
This drive is a little overt a month old, used only about a dozen times. I work on Macs (G4 & Intel MacBook Pro). The other day after copying files from my home Mac I dragged the drive icon to the trash to eject (which worked OK before) then removed the drive from the computer. I got an error message saying the drive was improperly removed and to always eject from the file menu. When I got to work I was not able to open any of the new files. They were all damaged and dates had been changed. Today I tried again and noticed the drive is running very slow and all files I copy to the drive keep changing their dates as I add them to the drive. Then I'm unable to open them on my work computer. (some older files previously saved on the drive were still intact). The new files are not the problem as I burned them to a CD and can open them on other computers, but after I copy anything to this flash drive they now become damaged and will not open. Can this problem be fixed and if so how? Thanks.
MS
  • 432 Answers
Run a check disk on the memory stick - most likely a good indicator that the flash drive is on its way out as they normally have a life span of about a year or two.
Posted on Apr 22, 2009
  • Shane Russell
    Shane Russell Apr 27, 2009
    If its only a month old it would most likely ( obviously ) be easier to get it swapped out and get a replacement or a refund.
  • 3,866 Answers
Yep, needs to be reformatted, first back it up reformat it and then try it again.
How do I download word documents to cruzer flash drive
From Word, use Save As.... and point the file to your USB drive. You can also open two instances of My Computer and drag & drop from the PC to the flash drive.
May 09, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a SanDisk Cruzer USB 2.0 Flash Drive. I need to transfer my data from my old windows98 computer to a new Windows7 computer. However, My Windows98 computer does not recognize my SanDisk Cruzer USB...
Take a router (wired or wireless), and use Ethernet cables to connect the two computers to the router.
Configure the old computer into the same "workgroup" as the new computer (and restart it).
Right-mouse-click on the folder containing the files to be transferred.
Click to enable "sharing" of that folder.
On the new computer, browse the "Network Neighbourhood".
It may take a few minutes for the new computer to "find" the old computer (working through the router).
Access the folder that you "shared".
Copy the files, over your private network, to the new computer.
Oct 03, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I just purchased an 8GB USB 2.0 flash drive from SanDisk Cruzer. I plugged it in, it recognized it then opened to documents what do i do next?
You use it like a floppy disk, you can copy files to and from your computer to the flash drive,then take the flash drive out and the put into another computer to share, ie. to download and copy files to from other computers such as a friend's computer. The files can be anything, music, photos etc.
Sep 28, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do I get info to correctly use my san disk flash drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Sep 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Titanium 8GB flash drive with files will not open
Microsoft has a fix for USB and other external peripherals.
http://support.microsoft.com/kb/925196#fixit4me
Hope this solves your issue. Good luck and all the best!
Greg
May 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cruzer Micro 8GB flash drive - no user manual
Plug it into the USB port. Press Windows-E to bring up the Explorer window, or start My Computer and open the removable drive.
You can then drag&drop files to/from the flash drive just as you do on the hard drive.
Feb 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I just bought a Sandisk Cruzer Micro, 8GB. My problem is that I'm rather computer illiterate. Can you tell me how to use this thing? Where to plug it in , etc. What do I do after its plugged in. I have...
1. Find a USB port on your computer usually it has a 3 pronged logo on it
2. plug it in, it will only fit in one way its a rectangle.
3. your computer if running on an operating system made after windows 98 will auto detect these jump or thumb drives.
4. you can browse to this new memory using my computer on a PC or by using finder on a MAC.
to copy files the easiest way i know to do so on both PCs and MACs is to select the files off of the source and drag and drop (or copy and paste them) to your new 8GB drive.
5. once you can see the files on the USB drive open them so you know the file is there and not a short cut.
You should strongly consider buying a second back up like an external had drive. you should have 2 back-ups of critical files.
-good luck-
Will
www.compressionconnector.com
Feb 19, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
298 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
