Question about Garden
2 cycle Murray Ultra front tines, quit pulling, will turn if you hold the front end up, but put it down and they stop. need diagram or manual of tiller
I had the same problem. It turns out the gear box was bone dry.
Remove both the left side tines, there is a grease fitting below and
to the right of the tine shaft. Before adding grease remove the air vent screw
which is located above and a little to the left of the tine shaft.(It has a slotted head)
Pump in grease until it comes out the air vent. Replace the air vent screw and the tines.
It appeared to me that there was probably never any grease in it
as it took quite a lot to fill and when it finally came out the air vent it was
new grease, not discolored like you would expect to see when you
would be pushing some old grease out with the new.
Posted on Jul 10, 2009
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Jun 04, 2009 | Garden
Put it in gear and as soon as it has a load it stops tines and wheels. Has trans grease, and have tried to tighten belt by the two side adjustments but it will not move? It is an older tiller Kohler engine...
It sounds like the key that holds the pulley on the front of the tiller transfer case has sheared into. Carefully remove the belt safety cover so the belts are exposed and start the tiller. With a flashlight look at the pully on the lower shaft and shaft area. Carefully engage the tines and see it they are turning. With a second person visually, from the side, inspect the pulleys to make sure they are turning. Now carefully load the tines and see if the pullies of shaft stop turning. If the shaft stops and the pulleys keep turning then the key on the shaft has sheared off. If both keep turning then you have something that has broken or sheered in the transfer case. This type of inspection is dangerous and needs to be done at a distance with a flashlight so you can see down in the shaft area when standing off to the side while someone loads the tines. It is very difficult to try and see if the shaft is sheered in the pully as is the case without the engine running. The key has friction and it is difficult to turn the tines with the drive engaged to the engine. The only other option is to disassemble the transfer case to see what has gone bad. Please be careful testing it. Good Luck, RAC
Mar 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Garden Logo
517 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
