Question about Refrigerators
Compressor going We own an Amana refridg. model # PARB2117AS1. I just had the repairman here because it was making an unusual noise. He informed me that the compressor is going. I am really upset about this because it certainly seems to me an appliance at this cost and age should serve us much longer than this without a major expense!! We purchased the refridg. in 2002. I am very discouraged and will not be looking at another Amana unless you take some responsibility for the repair. LU
    Guru:
  • 1,524 Answers
It is possible as Amana is now owned by Whirlpool which uses "Embraco" compressors. These have had issues. Contact the factory and tell them to send a supervisor.
Posted on Apr 22, 2009
Amana side by side refridg/freezer. Freezer not freezing, everything defrosted. Getting a buzzing noise then a click, then buzzing stops. Compressor overload?
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 20, 2011 | Amana ABB1927DE Bottom Freezer...
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
GE refridge temp control makes clicking noise
probably a few loose ends causing the rattle sounds it does it for most fridges.
May 11, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator compressor going
that's a good fridge i wood fix it if under 450.00
Apr 22, 2009 | Refrigerators
Buzzing sound for about 2 months
Compressor was replaced (also see additional comments made).
Mar 20, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Amana refridge
The humming noise is the compressor cycling on the overload protector. By the posted date I would think that you already replaced the refrigerator.
Dec 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refridge makes a loud noise
are you sure it is the compressor making the noise and what sort of noise is it. if it is the compressor, there is no cure except replacement which is not diy.
Mar 27, 2007 | Hotpoint HTR16ABSR Top Freezer...
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
