Question about Refrigerators
Need temp control for water cooler has BOTH HOT/COLD
Have a ELKAY upright water dispensor 5 gal water jug on top It is my understanding ELKAY solld to BRITA who does not stock parts looking for dealer or Tel # for replacement parts?
    Guru:
  • 1,524 Answers
Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
Posted on Apr 22, 2009
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
Oct 29, 2013 | Hamilton Beach Water Cooler with Storage...
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Dec 06, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    I need to know what king of 5 gallon water jug i need dose it need a cap or not i have 2 one with and one without a cap but the one with is empty
    It will work either way....it's just that the cap makes it easier to turn over and not spill
    Also if you have a cap you need to have the piercing thing...
    heatman101
    Feb 06, 2011 | Avanti Hot and Cold Water Cooler
    Automatic warm/cold water temperature setting does
    The temperature control board is bad . Pt # 388246
    Aug 17, 2009 | Kenmore 22422 Top Load Washer
    Elkay water cooler does not turn on
    You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
    May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Cold water doesn't get cold
    Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
    The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
    May 18, 2009 | Avanti Hot and Cold Water Cooler
    Refrigerators Logo
    145 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
