Question about Whirlpool Gold GB9SHKXM 18.2 Cu. Ft. Bottom Mount Refrigerator w/ Slide-Out Glass Shelves & Up-Front...
Whirlpool refrigerator/freezer combo with ice dispenser and water filter, only 1 1/2 yrs. old maybe. Seems to run A LOT, very noisy from when we first hooked it up. Almost like it's ready to dump ice all the time. Change filter every 3 months or so. Could it be something with the water lines??
  • 121 Answers
Sounds like there is a kink in the supply line
Posted on Apr 22, 2009
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
Mar 17, 2016 | Whirlpool WRF989SDAM 29 cu. ft. French...
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator and freezer smells like chemicals
Your problem might be something caught in the water hoses going into your fridge and condensation is freezing around it
Apr 03, 2012 | Whirlpool Refrigerators
The Ice maker seems to have stop making Ice... There seems to be water getting to the Ice maker.... Placed fingers inside of voide and there seems to be water but it is not freezing......... can you help
Have a look under the icemaker itself. See if there is a "test" button or switch. If so, press it , the ice tray should dispense the ice made and then return to its original position, then refil with water. Also make sure your water filter is clean or replaced if its more than 6 months old.
Jul 31, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a side by side Whirlpool frig/freezer, only a yr old, model #ED2KHAXVQ01. It has the ice dispenser & water dispenser on freezer door. The water and icemaker are not working and we checked for...
I can only think of a couple of things to check, 1. if there is a small screen on the end of the water line that delivers water to the refrigerator, it may be plugged, and 2. maybe the filter in the refredgerator it self is plugged.
Nov 06, 2017 | Refrigerators
Noise
The paperwork that you received at the time of purchase should list a telephone number to call for warranty service. This problem should be covered under your warranty.
Apr 14, 2010 | Whirlpool 17.6 cu. ft. Top Freezer...
Whirlpool side by side, 7 years old. not making ice
try using a hair dryer to thaw out the trough and remove the ice. please note the ice will run all the way up into the tube where it comes thru the cabinet.
this may have occured from your recent filter change as a new filter introdues alot of air into the water system and will cause these tubes to freeze up. in the future right after you replace your filter be sure to run aout 1/2 to 1 gallon of water thru water dispenser to clear air out of system. thx peyton
Jan 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped working
Hello pryorjonw. You may need a new dual water valve, because the part going to the icemaker may be bad, the ice sensing arm may be in the up/off position, the ice bucket may not be positioned properly not triggering the icebucket sensing switch, the condenser coil might be dirty, or the freezer may not be freezing enough to make ice while everything else seems to be staying frozen. To see if your freezer is cold enough, squeeze your icecream carton, as that is the first to thaw if there is a problem.
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
