Question about Roper REX3614KW Electric Dryer
Intermittant buzzing vibration like sound when drying.
Does not seem to be mechanical noise with drum rotation. Possibly happens when heating element is on. New Roper electric dryer.
  • 43 Answers
Check your lint filter may have lint filter alert.
Posted on Apr 25, 2009
Amana fridge periodically makes a buzzing noise 4 times every 3 min for about 10-15 min then goes away for awhile then does it all over again
is your ice maker making ice sounds like water solenoid or the motor that turns the dump fingers is stuck this will happen if the heating element is not working, After ice is made the heating element comes on for a few sec.to release the ice from tray then motor comes on makes a full rotation to push ice out.
Dec 16, 2012 | Refrigerators
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
My matag dryer is about 7 yraets old and it seems to be taking longer to dry? could this possibly be a heating element?
Not so much the heating element but the seal of othe drum to the door side and the back side need to be replace after long usage it get worn out and heat leak from the drum ...out
also make sure the duct from the unit to outside the house is clean from lint and dust...
Jan 03, 2010 | Dryers
Amplifier turns on and works till it gets hot then
This sounds like a problemn the power supply area, possibly near the filter caps. I would look for a cold soldering joint at or near the filter caps as a start.
The problem is a mechanical connection problem since vibration "fixes it".
Capacitors are heavy and often due to handling the soldering is broken at the terminals. As unit heats, these start to oxidize and break contact, but vibration temporarily restores them.
Dec 17, 2009 | Peavey Music
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Dryer vibrating alot and making alot of noise.
check the felt around the inside of the door to see if it needs to be replaced
Apr 23, 2009 | Dryers
Buzzing sound
This could be caused by vibration of the element coil supports (ceramic pieces that hold the element) as the machine is running. It could be intermittent due to the expansion and contraction of the coils when heating up and cooling down. See if moving the dryer while it's "buzzing" makes any difference in the sound.
If this is the case, you can replace the heating element or try re-leveling the machine. As a quick fix, tweaking the coil or supports is also possible but I wouldn't recommend this unless you feel comfortable doing so or you have experience.
Feb 15, 2009 | Kenmore 84052 Dryer
Gas dryer drum will not spin
the flint element might need to be replace...(pilot light) I had the same problem the dry had a burned smell...which meant that the element wasn't working properly and finally the drying wound't heat anymore
Jan 01, 2009 | Kenmore 98702 Stacked Washer/Dryer
Roper REX3614KW Electric Dryer Logo
90 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
