Question about Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX)
Configuration trying to get to the router configuration..using 192.168.1.. is this correct
    Scholar:
  • 132 Answers
Depends if the default IP scope has been changed. Is it up and running and you're connected to it? If it hasn't been hooked up before or it's been reset try 192.168.1.254. Unless its an enterprise router which is 192.168.1.1.
Posted on Apr 22, 2009
Why can't i connect
If by hub, you mean your wireless network (router), there is most likely one of two reasons. It may be possible that you are utilizing the incorrect security protocol, or that your router is not configured to communicate with the Wii 802.11 standards configuration.
In both scenarios you will need to dig into your router's configuration setup. Some of today's routers have this integrated into a program right on your PC or Mac. However, most router configurations are done via web browser. The specific IP or your router may vary from others. You can find it in your manual, or another good resource is www.portforward.com. There you can find a variety of different network improvement walkthroughs, but more importantly in your case you can find the specific IP(s) of your router, and also the original administrative credentials.
Once you have accessed the configuration you will need to find out what specific security protocol your network is using (the default on newer routers is generally WPA2 Personal). If it is not WPA2, you will need to manually configure your Wii's connections settings to reflect the correct protocol (the Wii's default is WPA). In this case and the next you will need to make the correct selections going through the manual connection process.
The latter scenario is much more probable if you are working with a newer 802.11ac compatible router or even more recent 802.11n dual band routers. From your router's wireless configuration menu you will need to verify that the wireless mode is setup to communicate with 802.11b and/or 802.11g (these are the two utilized by the Wii itself). Some of the more recent routers (especially ac models) may not be configured to work with the older IEEE standards. The newer routers may be configured to communicate with one, the other, or both 802.11n and 802.11ac. You will need to ensure that your wireless network is working with the legacy standards.
In all likelihood, correcting one of the these two things will enable your network to speak with the Wii. Good luck.
May 03, 2014 | Nintendo Wii Console
Cisco E3200 router configuration lost
The Cisco connect software came on the CD in the box with the router. If was used to configure the router when new. This can be used to fix the router now. I could guide you through a manual configuration but the software is a much faster easier method. I would recommend you try that route. Get the CD and run from there if you are worried about phishing.
Feb 12, 2014 | Linksys by Cisco Linksys E3200 Dual-Band N...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Using a laptop I trying to connnect the WNR200 witreless router and all connections are correct but cannot process network information?
First install the latest wireless card driver in the laptop.
Next to secure and configure the Netgear wireless router and configure the wireless card in the laptop with the Netgear's wireless settings, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | NetGear WNR2000 Wireless Router
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
I've got a belkin router modem wireless g+. after the configuration (repeated several times ) i can't use m torrent and the port test tells that my port is not correctly recognized. i tried to disable the...
Remove power from the router for 30 seconds and reconnect it. Go through the configuration process again.
Most port tests report a port as "open" or "closed". "Not correctly recognized" doesn't sound like a firewall problem.
Aug 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Interface will not come up to configure router
Use pin-hole to reset router. Try default 192.168.1.1
May 21, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Pings-no-pongs
well, try to check if you configure your xbox360 properly, if it is correctly configure, well better check the cable which you used to connect your xbox360 and your router.
Mar 12, 2008 | Computers & Internet
Router Dell-Wireless 2350 (Linksys)
First try to check if your router is really configured correctly. Then try to check your banwidth, because bandwidth can also make your computer freeze. Then check also your cable if it is ok. Then try also to check the disk space in your computer because if your disk space is full or almost full it can also make your computer to freeze.
Aug 20, 2007 | Dell TrueMobile 2300 Wireless Broadband...
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
111 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
