if you don't know what u are doing u shouldn't mess with video head. U can easily damage the head. If cleaning tape does not work have tech do it. Should be relatively cheap.
My 2002 Sony 57" died last month. The cost to fix the B board and install three new tubes will...
(More)
My 2002 Sony 57" died last month. The cost to fix the B board and install three new tubes will be $815.00. I decided to buy new.
I would prefer a 70"+ plasma, but with the $40k price tag. NO thanks. Anywayz.
My living area is rather large. I sit 14 feet back from the TV, so a larger screen size will suit my needs much better than the average 42-50" displays.
I have been looking at the mitsubishi 73" and 82" series C9 (73" only), 737 and 837 series. I have read several complaints on older mits models, but have come across few or none concerning the new model series listed above. I understand the lamp will need to be replaced and I guess I would deal with that problem once a year or so, if it were.
I would like some advice and thoughts regarding these models. I wonder if it would be a decent investment or would I just be entering into trouble land. If the problems are to problematic I guess I would just settle with a 65" but get the panasonic plasma, which I don't think I would have any issues with.
However, due to the living room size, I would like to settle for the larger display IF the newer series mits are quality items.
Thank you for your response.
The screen is black. when it is switched on the button blinks green slowly then start blinking...
(More)
The screen is black. when it is switched on the button blinks green slowly then start blinking faster, then it starts blinking red and at this point you can not shut it off with out cutting the power. I put in a lamp but this didn't solve the problem and the original bulb doesn't look burnt out.
