Question about Tomtom ONE GPS Receiver
GPS Won't work
I turned my Tom Tom on this morning and it will not exit the first screen and I can not shut it off.
  • paulb8821 Apr 23, 2009
    wont exit the first screen and wnt shut off
  • 3,866 Answers
Try to see if there is a pin hole reset button on the unit. if there is use a paper clip and reset the unit to factory defualts.
Posted on Apr 22, 2009
Several of TomTom's models have this problem when the battery power is low. What happens is that when turning on the device, it takes a lot of power to boot up. If the power level is low, during boot up, it brings up the image then right at that moment, it freeze because it doesn't have enough power to run the rest of the boot sequence.
The solution is to leave the charger connected to the unit for some time, and try to turn it on and off a few minutes later. Sometimes it won't work until you try it a few times. You can also use the reset button to turn it on and off if you have a pin. Once there's sufficient power, just leave the charger connected when you drive. As long as the battery is not at critical level, this problem should not occur.
Posted on Apr 24, 2009
Tom Tom powers up to completely blank or sometimes faded screen. Frist noticed this problem powering up on a very cold 15 degree morning GPS was in the car all that night so it got cold.
These things don't especially like the cold weather. I did the same thing once, with the same result. Once the unit warmed up it worked fine. consequently, I no longer leave it in the vehicle at night.
Jan 28, 2010 | Tomtom ONE GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Screen stuck on tom tom with red hands
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
It should now work
Sep 21, 2009 | Tomtom GO 300 GPS Receiver
Tried to update my Tom Tom One by connecting to my
Remove the SD card
Update your device without the SD card.
Make sure your GPS runs OK without the SD card
Now re-connect the tomtom but don't let tomtom home run. exit TTH if need be.
then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work again
Sep 14, 2009 | Tomtom ONE GPS Receiver
When turned on, screen has picture of unit with blinking "x" in lower right side and what looks like a "disc" in lower left. will not respond.
Remove the SD card
It should now work
Sep 11, 2009 | Tomtom Go 700 Portable GPS Receiver
Tom tom won't turn off
if it does not proceed when the icon is selected, presume data corruption or in fact no data.
TomTom is renouned for this type of problem.
try rteinstalling the map data from the source.
try a reset first ( small pinhole on rear) put open paperclip end in and gently push the button inside) if this still fails then data installation is the go
Jun 23, 2009 | Tomtom GO 720 GPS Receiver
No GPS Signal in TomTom One XL all of a sudden
I suddenly lost the GPS signal today and could not get it back. All I got was the "No valid GPS signal". My solution was to tap on the GPS satellite bars when in the route map. this brought up the "Status summary page of the TOMTOM.
I then again tapped the satellite bar which brought up the "GPS Status" page. I then tapped the bar labeled "configure".
The radio button next to the option titled "Minutes (dm.m') was selected. I then moved the selection to "Degrees (d.d) and it started working.
I had just downloaded the GPS fix 5 days ago so it is not like this suddenly caused it to stop working.
This may not work for everyone but this is what it took to get mine working.
Cheers
Jul 09, 2008 | Tomtom One XL GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Tom tom 3
This is a battery save setting.
Check settings under Battery Saving Preferences, choose Never Turn Off Screen
Apr 03, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
176 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
