Temp stuck on hot on my front loader washing machone
All my washing is coming out creased and the temp seems to keep on hot
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
Water temperature is controlled by a switch which activates or deactivates the hot and cold water solenoids. Replace this switch, it is not expensive.
Posted on Apr 22, 2009
I need a manual for Lg Fuzzy Logic
Request a manual directly from LG.
Jan 11, 2015 | LG Washing Machines
Tricity aw 1000 front loader washing stuck in will not open
Does the y splitter have little valves on it? Make sure both are open.
Nov 28, 2013 | Tricity Bendix AW1000W Front Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
What Temperature is crease guard. also fast wash on hoover 1300
usually crease guard is a combination of hot and cold (warm depending on water temp and water pressures)
Hoover fast wash is generally a shorted time cycle of the normal washes
Nov 20, 2009 | GE S8000E
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Clothes smell from Kenmore Front Loader
run 3 cups of bleach on high water setting with hot selected as water temp, repeat as ness to eleminate odor
Sep 11, 2009 | Washing Machines
Whirlpool duet sport
if its new top loader needs water temp switch need more infor "less soap plz"
Nov 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rubber Seal not Sealing
This seems to be a common problem with front loaders, but there is an easy fix if you follow these simple steps:
1. The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first.
2. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions.
3. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this.
 Good luck and I hope this helps you.
Oct 24, 2007 | Kenmore Elite 45986 Front Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
