Philips TV, Model # 50PL9126D/37
We turn the TV on the blue power light on the front turns on, everything is fine for about 15 seconds then the screen goes black and 2 red lights (the lamp and temperature lights) come on the power button. The sound is fine but there is no picture. My husband opened up the TV and found that the lamp comes on, gets brighter and then just shuts down. I need to know what exactly the problem is as I wouldn't think it to be the lamp alone as it comes on and gets bright. I am just praying it is not the lamp engine because then we are talking $900 to fix.
  • Anonymous Jun 15, 2008
    yep...met too!
  • Anonymous May 04, 2009
    have the same thing
  • 105 Answers
Check to make sure all the ventilation opening on the tv arent plugged. if not, then you will have to make sure all the fans inside the tv are working properly.
Posted on Oct 14, 2007
SOURCE:
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips 50PL9126D/37. I began having my screen go black (audio still playing) and a red light appeared in my blue power button. I removed the back of the television and checked the lamp, which was...
You cooould have a bad ballast, but it's probably either that you put the lamp in wrong, or you have a defective lamp though. There's a 33% chance that any of those are the case. Unplug the TV for 30 seconds. Plug it back in. Try turning it on again. Make sure you didn't over tighten the lamp during install. Especially the screw on the side. It should be a tight connection. Send the lamp back and get a new one. Usually they come with a warranty. If the new one doesn't work, it's either the ballast, or the power supply.
Jun 16, 2011 | Televison & Video
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have Philips 50PL9126D/37 The red light on the front where the power indicator is keeps coming on. What does this mean? When it comes on my screen goes blank. Any suggestions?
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
Apr 05, 2011 | Philips 50PL9126D/37B 50" DLP TV
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Problem with philips dlp tv
This sounds like one if not both of your cooling fans are not functioning properly. Therefore, you'll need to replace a fan more than likely.
Apr 16, 2017 | Televison & Video
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Televison & Video Logo
1,445 people viewed this question
Top Televison & Video Experts
Ekse
