Question about HP LaserJet 1100 Printer
My hp laserjet 1100 doesnt respond when i try to print
And when it does work my hp laserjet 1100 is only printing one line of code of on the top of page, it rarely works anyway and usually takes about 50 tries to print some thing. i have the printer connected to a dell pc with microsoft vista via usb. before when i tried to print something, it wouldn't print and had an error message. i try unplugging everything and plugging it back in, reinstalling the driver, ive used different usb ports on my computer, rarely works. the times it has worked, it workes fine, but i dont know what causes it to decide whether or not to work correctly. i need help.
  • Anonymous May 07, 2009
    I have exactly the same problem
  • 432 Answers
Not sure if this will help but if you right click on the printer and go to properties ( when your in printers and faxes ) and go to the ports tab I think it is and un tick the check box that says bi directional support and try it again.
Also what error are you getting thats printed off ?
what lights are on the printer and where are you getting the driver from, if the disc then try the latest driver from the hp website
Posted on Apr 22, 2009
My printer doesnt print and it is connected on a serial port it just says printing and nothing happens
Hi!
Make sure the cable hasn't died, and check to see if the printer is working by printing a test page, usually done on HP's by pressing and realeasing the green go button, or holding down the power button. If the printer responds, and the cable is ok as far as you know, check and maybe reinstall the drivers with the disk that came with it.
Good Luck, Hope this helps!
Nov 28, 2010 | HP LaserJet 1100 Printer
HP Laserjet 1100 - prints test page text & image on envelopes
try to uninstall the drivers and reinstall them it should fix it
Jul 20, 2009 | HP LaserJet 1100 Printer
Hp laser jet1100 prints white lines
Hi ejazmusavi:
Try this.
Toner/developing cylinder 37.7 mm (1.48 inches)
Toner/primary charging roller 37.7 mm (1.48 inches)
Heating element 56.5 mm (2.22 inches)
Transfer roller 45.2 mm (1.78 inches)
Pressure roller 62.8 mm (2.47 inches)
Toner/drum 75.4 mm (2.97 inches)
Feed roller 55.1 mm (2.17 inches)
Hope this helps
May 29, 2009 | HP LaserJet 1100 Printer
My HP LaserJet 1100 prints a line of @'s
This is either a bad driver, which you can reinstall from your PC or the formatter is no good.
Mar 18, 2009 | HP LaserJet 1100 Printer
LaserJet 1100 printing problem
did you select the correct printer on the print details screen? also try go to the conrtol panel and delete the hp prinret program then re install/download it on line from hp.also if when you get it going if it feeds more than one piece of paper at a time they make a kit to fix this{its a little piece of plastic}. also if you cant find the program in the cp you may have deleted it al ready, just go downloaded it. good luck..
Jan 14, 2009 | HP LaserJet 1100 Printer
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
Hp laserjet 4250dtn PROBLEM
try replacing the toner cartridge, if that doesnt work, let me know
Apr 03, 2007 | HP LaserJet 4250dtn Printer
HP LaserJet 1100 Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
