Question about Virtual Reality Sound VR3 CD Player w/ USB and Scan Disk Inputs
Help installing in a 1996 dodge avenger
I purchased the cd player today and I can't for the life of me figure out how to install it in my 1996 dodge avenger. The wiring is just too weird. Any help you could please give ?
    Problem Solver:
  • 10 Answers
Go to the12volt.com they should have all the info you need
Posted on Sep 24, 2007
SOURCE:
Have a 2008 Dodge Avenger, cd player not wking, think a cd is stuck, what do i do, bought vehicle used
You must remove the CD player and send it out to a factory approved repair facility, cost about $200 USD
Nov 02, 2016 | 2008 Dodge Avenger
How much is it to replace 2008 dodge avenger cd player lens?
Please check with your local electronics repair shop if they have that service replacing CD player lens, price varies.
Feb 28, 2011 | 2008 Dodge Avenger
1996 Dodge Avenger ES 2.5L All I get is a click
Check Battery connects,Cables.Clean !Also to engine ground. Then Alternator belt tension.Listen for slippage. Check connection on starter relay,and bolts on starter, tap on starter while a buddy starts engine,with the key. Could be bad brushes in starter and or bad relay at starter.
Sep 16, 2010 | 1996 Dodge Avenger
Is there a manual to teach to install rear brakes 208 dodge avenger
There is a manual, It's on CD. I believe the Dodge Caliper has the same brakes. If you can' get the drum off you have loosen a screw in the rear with a screw driver. My family has been changing brakes for years. You don't have to have degree to do this. lol Here's a link to the diagram for a 2008 Avenger.
Sep 23, 2009 | 2008 Dodge Avenger
My 96 dodge avenger doesn't seem to want to shift. it try's
you really need to have a diagnostic scan performed on it and also see what codes come up and you may most likely need to rebuild your transmission or maybe just have a shift kit installed which isnt all that much money.
Jul 26, 2009 | 1996 Dodge Avenger
How to load in cd's to in dash 6cd player
Go to player menu until the display shows load and then press a # to load cd into a slot. My friends new Dodge drove me crazy for two hours because I didn't press a # for load location. ( # = 1-6)
Feb 09, 2009 | 1996 Nissan Maxima
1996 dodge avenger
sounds like your having a problem wiring the cd player. are you using the correct wiring harness? I just installed a cd player in my 1996 avenger and had no problems, the only thing i had a problem with was that the stock radio was malfunctioning seemed to be fixed once i installed the new cd player
Sep 25, 2008 | 1996 Dodge Avenger
Sterio wireing problem 1996 dodge avenger
To my knowledge most 1996 Dodge Avengers do not have a ground wire, instead, it uses a braided strap screwed into the rear of the radio unit. However in some units, the ground uses Black/Yellow.
Additionally:
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 16, 2008 | 1996 Dodge Avenger
Set Clock
Here's the link to the manual; http://books.jvcservice.com/download/686537201/34916.pdf page 9 should help you out :)
Apr 11, 2007 | JVC KD-G210 CD Player
Car Audio & Video Logo
Top Virtual Reality Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Bill Boyd
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
