Question about Microsoft Windows XP Home Edition
When i start uo I get "windos starting up" then "cwindowssystem 32lsass exc terminated status code 1073741819". and after 60 sec it tries to reboot but only repeats the same
  • 66 Answers
Normally this happend if there is conflict with the third party services . Try to log on to safe mode using F8 key while restarting
use msconfig command to disable third party services.
  1. Click Start, click Run, type msconfig, and then click OK.
    The System Configuration Utility dialog box is displayed.
  2. Click the General tab, click to clear the Load System Services check box, and then click OK.
  3. When you are prompted, click Restart to restart the computer.
If these steps helped you start your computer in a clean-boot state
then there is a problem with some third party service like norton or any other software
Posted on Apr 22, 2009
Error code 11:27 "Level Offset"
The suspension units in those machines do the weighing - strain gauges fitted. May need new units, or electronics, but expensive just to guess - join a service scheme like domestic and general if in UK, who will allow you to join even with a faulty machine - the call the manufacturer out! Level offset sounds like it can't find it's 'empty' position point.
Dec 30, 2017 | Electrolux Washing Machines
Tip
Super fast shutdown
if u want to shutdown ur pc faster or slower:
1- start-->run-->regedit
when u start run and then write regedit
2- +HKEY_LOCAL_MACHINE
+SYSTEM
+CurrentControlSet
Control
left kick on control and u will find WaitToKillServiceTimeout.
dobbel kick on WaitToKillServiceTimeout.
in WaitToKillServiceTimeout its 20000 it means 20 secunds...if u want to shudown windos faster then get the numbers smaller, like 10000 or 5000 (10 sec or 5 sec) or if u want to shutdown longer writ 50000 (50sec).
on Mar 01, 2008 | Microsoft Windows Vista Ultimate Edition
Frigidaire dish washer FDB4315LFo Error code uo
You are experiencing a vent issue - While in wash cycle, Main Control Board does not receive signal from vent assembly that vent plunger is closed. Plunger status is sensed with optical sensor in vent assembly. Check wiring between vent assembly and Main Control Board. If wiring correct, replace vent assembly. If error still exist, replace Main Control Board.
Sep 04, 2012 | Frigidaire Dishwashers
2005 Volvo S40 High temperature light comes on and now it won't start
Seems like the temp sensor is grounded after the heat up, Unhook the battery positive terminal for 3 minutes, make sure the coolant is full in the radiator, hook the positive terminal on the battery and start the vehicle, IF it does not start scan for codes and let me know, what codes you find?
Jun 20, 2012 | 2005 Volvo S40
2009 KTM 300 EXC will not start
Hi, Nickstar15 before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KTM 300XC Electric Start
KTM 300 starter problems and solution
KTM 250 EXC EU Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 125 EXC SIX DAYS Owner Manual
Oct 14, 2017 | 2009 KTM 300 EXC
WHEN THE SECURITY LIGHT IS FLASHING,WON'T START THE SUBURBAN,SO WHAT SHOULD I DO?
Reboot the system, put the window down,(just in case ) and if you got a radio code you ll need it if you have that type of radio. Disconnect the vehicle battery, put terminal together. 15seconds is all that is needed , and reattach, go in the vehicle and put key in ignition in the ACC for 30 sec. put in off position start the vehicle.
Apr 28, 2011 | Chevrolet Suburban Cars & Trucks
Hello, I have a problem with an intermittent &
sounds like you have a poor earth connection, possibly between the coil and the frame, try quickly rigging up a cable from the mounting point on the coil, to a bare metal part of the bike (or nagative battery terminal if available), and try again.
Hope this helps
Mar 29, 2011 | 2000 KTM EXC 250
DeskTop PC Rebooting
On a pc this old the capacitors start to dry up. If it's that then it's time to buy a new pc.
Simple test: try going in the BIOS. If (by miracle) you can, change the boot order and put the cd first. Then boot from a Linux Live-CD like http://pclinuxos.com/
If that works then Windows was completely corrupted by malware. Reinstall and next time use a better antivirus.
Feb 13, 2010 | Intel D865GBF Motherboard
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
