Question about GE Profile PCF25PGW Side by Side Refrigerator With Ice Box
Temperature to warm
The freezer stopped freezing and the refrig is not cool enough- It worked fine and I had the ice maker/water dispenser hooked up. It worked for a week or two and then it stopped making ice. There is an ice build up on the back wall of the freezer but it wont freeze. I dont know what to do or how to fix it.
  • palasprinces Apr 22, 2009
    how do I know if it is the timer, heater, limit switch or mother board. I was going to turn it off and let it defrost overnight. Then turn it back on to see what happens after that. What advice can you offer that might help me to find resolution. My budget isnt going to allow me to call in service repair. So anything that you can offer that might help would be appreciated.
    Thank you
    Guru:
  • 1,524 Answers
This model uses Adaptive Defrost Control (motherboard) which has probably gone bad. Located on the back of the refrigerator.
Posted on Apr 22, 2009
  • 1 more comment
  • Robert Moller
    Robert Moller Apr 22, 2009
    Try this :http://appliancejunk.com/ge/refrigerator...
  • Robert Moller
    This unit uses an ADC (motherboard) and is a lot more then $10.00
  • Robert Moller
    Robert Moller Apr 23, 2009
    This from Appliance Aid.Com: WHY Force the Arctica to Defrost if it Don�t Want to? Don't
    bother using the self-diagnostics feature to force a defrost cycle. On some
    models � those with control knobs - which technically are not Arctica models (Arctica
    models have plastic liners with touch pads � Standard GE electronic models
    with metal liners have knobs) servicers would have to invest in parts to build a
    �test� control panel, complete with touch pads and digital displays, to
    achieve this (self-diagnostics) function. Instead, save both time and money by
    following this helpful Arctica Tip: If a frosted evaporator or a �frost
    block� is apparent, initiating a defrost cycle may not reveal anything helpful
    anyway. First, disconnect power and then simply check the resistance across the
    defrost heater and bimetal circuit at the main board located at the backside.
    The two associated wires at the main board are almost always BLUE and ORANGE.
    The heater/bimetal circuit should normally read around 30 ohms roughly. Next,
    check the evaporator thermister at the main board between thermister input
    terminals J1-4 (Blue/White) and J1-5 (Blue) to determine that its resistance is
    greater than 1.2k ohms but not more than 166.8k ohms depending on its ambient
    temperature. If thermister resistance falls within this range according to
    temperature (Approximately: 6k ohms at 70�F � 16.3k ohms at 32�F � 51k
    ohms at 0�F) and the heater/bimetal circuit is diagnosed as good, then replace
    the main board. Note: Always check the tech sheet per specific model to verify
    wire colors and terminal locations.
  • 121 Answers
That is an automatic defrost problem
timer,heater or limit switch
  • lojacksdad
    lojacksdad Apr 22, 2009
    if you let it defrost overnight it will work for about 24 to 48 hours
    before freezing up you need to locate the timer and change it first
    that is the easy thing to do first timer cost about 10.00
    the other things are harder and require a multimeter
    i hope this helps you
My water in my ice maker is warm and there is a smell like a backalite coming from freezer
Its not cooling properly,the issue is weak or dirty compressor section and related parts.Get the refrigerator serviced completely and see if its help.Otherwise compressor needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Blank screen on gr l 247ni refrigator how to repair
Faulty control panel.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Water do not get cold it stay room temperture and stay warm.
Its faulty compressor if freezer section is also not cooling.
But if freezer section is working fine,then problem is confirm defrost assembly.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Samsung fridge RS2555SW is not working. all temp lights are blinking. can you help
May be it needs reset. Unplug the unit for 12 hours and then reconnect to see if that makes any difference.
These will help.
Thanks,.
Dec 22, 2012 | Samsung Refrigerators
Refrigerator model rb215labp The fridge freezes, fridge drawers freeze, top shelf is too warm
Its not working.Two possibilities,either faulty compressor or issue with defrost assembly.Defrost cycle not working.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
GE Profile PCF25PGW Side by Side Refrigerator With Ice Box Logo
247 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
