Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Maytag dishwasher MDB6100 light flashing
The heated dry light is flashing on my dishwasher - it won't start up - any idas?
  • 1003 Answers
SOURCE: Maytag MDBH950AWS Dishwasher won't start
Posted on Jan 18, 2008
  • 77 Answers
SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Posted on Jun 07, 2008
SOURCE: frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Try running the hot water in your kitchen sink until the dishwasher kicks on.
Posted on Sep 16, 2008
  • 9 Answers
SOURCE: Won't start. Light on next to "heated dry" button & "#3" graphic
You have the lock activated. press and hold the HEATED DRY button for 3 seconds
Posted on May 13, 2009
SOURCE: Maytag Quiet Series 300 Legacy Series Dishwasher
Mine was doing the same thing and I just pressed and held down the heated dry button until the light went off. Then I was able to start my machine as usual. Hope this works for you.
Posted on Jul 02, 2009
SOURCE: I have a Maytag Quiet
The "3" means hold for 3 seconds to child proof it. When it's on, none of the functions work. When you hold it again for 3 seconds, it turns off and your buttons will work again.
Posted on Oct 06, 2010
0 characters
1 Points
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from
Why won't my dishwasher start and why does the "Heated Dry" > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Maytag mdb7749awb1 won't start
Thank you very much after doing the normal heated dry three times all the lights on the panel lit up and my dishwasher started running
Aug 18, 2012 | Dishwashers
My maytag W10199645 dishwasher won't start
Maytag model w10199645 was starting intermittently, and sometimes only when we pressed and held the start button for 10-15 seconds. Finally tonight it just wouldn't start, period. I unplugged it for 15 minutes, then used the Heated Dry/Normal/Heated Dry/Normal and it started back up on its own.
Mar 23, 2012 | Maytag Dishwashers
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Dec 30, 2011 | Maytag MDB7749AWB Builtin Dishwasher
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Indesit DI 620 dishwasher lights 2 and 4 flashing
Lights 2 and 4 flashing - can't start machine. This fault not covered in manual.
Apr 21, 2009 | Maytag MDB5100A Dishwasher
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Apr 17, 2009 | Maytag 24 in. MDBH950AWS Built-in...
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
269 people viewed this question
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike Cairns
Mike Cairns
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
