Question about IBM ThinkPad R40 2722 Notebook
I have a psp version 5.00 the memory cards fine i have formatted it the usb cable is fine i run windows xp my pc dosent recognize my psp
  • 55 Answers
Not to be a **** but is the PSP set to USB mode? if it is you may have to reinstall the USB drivers on the PC.
Posted on Apr 22, 2009
  • 3,866 Answers
Well xp does not reconize anyting over a certain GB anyways so that is one issue, the other issue is way XP handles the mass storage for this Device and drivers need to be updated.
My computer dosent run my psp program with a usb cable so i can sync anything in, how do i make it recognize my psp
When you connect your PSP to your computer, it won't recognize the PSP immediately. After you connect the PSP, you will have to navigate to USB Mode on the XMB. Your computer will recognize your PSP as a mass storage device.
Good Luck.
Mar 18, 2011 | Sony PlayStation Portable (PSP) Console
How to upload pictures? what are the properties of a PSP image
Hi, charlesleigh!
The PSP supports most common image formats, to upload the images do the following
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
If this didn't fix your issue please let me know. Hope this helped you!
-Luchen
Mar 07, 2011 | Sony PlayStation Portable (PSP) Console
How do I put photos from my comuter onto a 2gb sony memory stick
  2. Turn on the PSP.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.....
hope this helped..good day..please vote...
Dec 11, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
Psp usb problem..unrecognised memory stick..
DID U FORMAT UR MEMORY ANDIF U DID NOT FORMAT UR MEMORY THAN SEE IF U HAVE UR USB CHRGE ON DISABLE IT AND ULL B ABLE TO GET INTO UR PSP VIA USB CABLE CONNECTION
Jun 30, 2009 | Sony PlayStation Portable (PSP) Console
Mpman sd card not recognized
You will not be able to transfer the songs to your media card and then transfer it to your device..
you will need to transfer it directly to your device from the computer...if you want i can send you a link where you can obtain your device USB cable.
Let me know if you need additional help
Thank you
Computerrep
Mar 06, 2009 | Audio Players & Recorders
Pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
May 27, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Transfer pictures from windows XP to psp
connect your psp to your pc with your usb cable then in the options of your psp connectby pressing usb. then in my computer on your pc there should be a new drive. in that drive there is a folder for pictures. just put them in there. If its not the transfer thats the problem and its just certain pictures it might be the format i think psp supports .jpeg, .jpg, .jfif, .jpe, .png, .gif, .tiff, .tif, .bmp, and .dib pictures
Sep 05, 2007 | Sony PlayStation Portable (PSP) Console
PC doesnt recongize my memory stick as a formatted memory stick...
Do both systems run XP? Also, check the driver files on your PC, and test it with another card of the same make. Is the write-protection switch set to on? Test the card reader with other formats of cards, if it is a multiple reader, just to make sure that it is functioning at all.
Jun 04, 2007 | Sony PlayStation Portable (PSP) Console
IBM ThinkPad R40 2722 Notebook Logo
74 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
