Question about HP Bestec ATX-1956D 200w HP Part No 0950-4106 (ATX1956D) Power Supply
No voltage output
I have a bestec power supply, and need a diagram for model atx-1956d, can you help please?
  • rocamarder Apr 23, 2009
    thanks for your help.
  • HP Master
  • 3,866 Answers
Would recommend replacing this unit instead of serrviceing it yourself it will cause adverse effect and may even smoke. These units once they dye there gone. If you need a diagram I would direct you to www.apex.com.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
Switching trangister is always blow offf
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Nov 02, 2011 | HP Bestec ATX-1956D 200w HP Part No...
How to troubleshoot Bestec ATX-1956D Power supply to determine if it is the power supply or another computer component..computer will not power up green light on power supply goes dim but does not flash...
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue.. Many computer shops will test for free.
Oct 06, 2011 | HP Bestec ATX-1956D 200w HP Part No...
Problem with the HP Bestec ATX-1956D 200w HP Part No 0950-4106 Power Supply What voltage is P7 connector on this p/s and what is the pinout of this 3 pin connector... 2-black leads an a green lead?
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Jan 16, 2011 | HP Bestec ATX-1956D 200w HP Part No...
No Power out put.
short the color green and black of your atx... use a metal wire.. don't wory it won't harm you... just unplug all the connection that is connected from you ATX.... short the said wire then plug your ATX to the outlet.. if fan is running then there's no problem on your ATX.. if not then you need to replace a new one...
Jul 20, 2009 | HP Bestec ATX-1956D 200w HP Part No...
What is the p7 connector on a atx-1956-d for? the upgraded power supply has no provision for this connector? help please!!!!!!!!! gjohannsen@verizon.net
This is not a problem, and as it sounds, is not used in your system.
Some video cards have such huge processing power that they need thier own supply, as it would draw too much current from the motherboard otherwise. Below is a web site which reinforces this information, and gives an explanation of each connector.
http://www.affordablesurplus.com/bestec-atx-1956d-power-supply.asp
Or do I not understand you. Do you have one less, or one too many?
Apr 13, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Upgrade for Bestec ATX-1956D (HP p/n: 0950-4106)
How about the LC Power LC350M Micro ATX - 380 Watt
or the
Logisys 350W Micro ATX
They should fit your form factor and output as much as 350W being relatively cheap, but neither gets 18 amps on 12V rail...
I think no power supply of that size has an output like that...think about a cheap but substancial chassis upgrade if you need that power...Have a look at directron for the PSUs.
Feb 13, 2009 | HP Bestec ATX-1956D 200w HP Part No...
My part not turn on wt' can i do
Not worth wasting time diagnosing/repairing a bestec...
afraid to say purchase a new part...
Matt
Jan 22, 2009 | HP Bestec ATX-1956D 200w HP Part No...
I feel like an idiot but, I cant seem to find the fuse in my power supply. It is a Bestec ATX-1956D. Help please
don't feel too bad... i don't think you will find one externally on those... the fuse is usually soldered to the circuit board. what issue are you having ?
Robert
Jan 10, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Computers & Internet Logo
459 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
