Question about Hitachi DMP-7 MP3 Player
Hitachi DMP450N is dead
Only a month old, plug into pc, screen lights up then goes dead, pc says device has malfunction. Now won't turn on. Anybody else had this problem?
Yes - I have the same problem - did you ever resolve the issue?
Posted on May 05, 2010
Slove to video can't player?????
Posted on Dec 10, 2009
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
Tip
Monitor LCD Screen Replacement With A Laptop Screen
This tip is for the typical PC tech with a shop full of dead laptops and monitors, looking to make an extra Monitor for bench testing malfunctioning PC's. Maybe you're a tinkerer and just have some spare parts laying around, and want to make something cool and easy. Either way, this tip is a fun way to make old dead parts work for you, rather than sitting in a corner gathering dust.
Replacing a Laptop screen is pretty easy if you take it slow.
LCD Monitor screens are actually easy to replace too, if you are careful not to crack anything getting one out and in again.
This tip doesn't address any of the typical replacement methods.
What this does is show you how to use a laptop screen in a standard Desktop LCD monitor.
Having already disassembled your Desktop monitor, and determining that one or both of your backlights is dead, you will most likely begin searching for sources of a new one. Before you do that, try testing both backlights in the dead monitor screen first by hooking them, one at a time to an inverter in a working laptop to verify that both are dead.
Most of the time, you will discover that only one light is dead, and this is where the fun begins.
At this point, you have a few choices to make.
1. Extract a working backlight from a cracked LCD, we all have a few of those lying around somewhere in just about any PC tech area.
2. With the extracted backlight in hand and the old LCD screen still attached to the monitors electronics, remove either of the sets of wires going to one of your backlights, leaving one still attached.
3. Now you can attach the light you extracted to the empty socket your original screens light attached to, while leaving the other one still attached.
4, Now, turn on the monitor and wait for the extracted backlight to come on, if it doesn't switch it with the other light socket plugged to your screen, and plug the opposite light wire back in.
This will do 2 things for you. First, it will be a quick test of your inverter, and second it will verify that you do or don't have at least one working backlight still functioning in your monitor.
Remember that with most LCD monitors, just one backlight can provide enough illumination for your screen to show a very crisp picture.
The problem appears though, when we decide that our existing LCD is dead because we dont see it light up.
The solution for this is to simply disconnect the dead light wire from the existing inverter plug leading to the LCD screen, then replacing that with a working light from the cracked screen without disassembling the LCD screen itself. If you did everything right, your old dead screen will be working as it should. Be sure you swap the backlight connecting wires so that your Bright/Dim controls work as they did before.
You see, most dual light inverters work the same as a standard twin tube household flourescent light. When one goes out, they both eventually stop working. So, adding that second light completes the circuit, then swapping light socket connectors turns your backup light tube into the primary light, instead of the secondary.
Now, if THAT trick didn't work, you can move on to the Laptop LCD trick, which is pretty much what you did before, except that the Laptop LCD usually only has 1 light tube. So for this to work, you can complete the lighting circuit by simply adding your spare backlight tube to the second open backlight connector, then installing the LCD to your monitor.
Many of these Laptop LCD screens are the same height and width as comparable Desktop screens, but they are also thinner, and will have to be glued or taped to the frame from the inside. Everything else connects exactly as the original screen, but may need to have wire added to the Laptop backlight wire so it reaches the power source.
I figured this tip was worth posting, since I just did this trick with a 15" polaroid HDTV/HDMI/HiDef Television/Monitor combo.
The model I have died a few months after it was bought new from Walmart, and the customer just didn't feel like paying $129 for a new screen.
Being the packrat I am, I just couldn't bear throwing it away, figuring that some day I would find a matching screen. As you can see, I got tired of waiting. The pictures of my project are below.
That bright line of light isn't the flash from my Camera, it's the flourescent light tube from a broken LCD screen placed on top of the steel housing.
The incidental effect of that light is that my back wall is a nice nitelite, and hooking up new components is a lot easier. Yes I could have blacked it out, but I think I like the added light behind the TV.
I hope this Tip comes in handy for you.
Bob S.
on Apr 08, 2010 | Computers & Internet
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
I turned on the printer and it won' go. no lights dead.
Is this new? Was it working before in the same place with same pc?
Check power supply. Plugged in?, Local breaker at socket? Test meter the power plug that goes to printer. Still dead? Use as door stop. If new purchase, and still dead, take back for exchange or refund.
Nov 26, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
MY COMPUTER WON"T TURN ON YET INDICATOR LIGHT WHERE CHARGER GOES INTO IT SHOWS LIGHT> Plugged in but will not powerup screen black. THIS IS A G60 HP Laptop
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 16, 2010 | HP G60-235DX Notebook
Two months old dead no power
Check the Power cable of your PC for any damaged or burn/cut. Firmly check the connection on the slot of the CPU Power Supply,
Check the Electrical outlet , or better plug the cord on a different electrical outlet.
If all of this has nothing to do and the problem was still there, possible problem on the powersupply are, it is advisable that you have to replace this part, a possible burnt or a short circuit has happen inside, due to some electrical malfunction on your area.
HOpe this helps.
Let me know for any clarification
Oct 08, 2009 | ASUS Computers & Internet
Controller stopped working completely
Did you charge it ????
Will it charge when plugged in ??? (Blinking red light on controller??)
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Unable to download videos on to hitachi dmp450n device
either you need to buy precompressed videos, meant for your player, or you need to buy (expensaive and illegal) software to compress and change the format of your videos.
Apr 04, 2009 | Audio Players & Recorders
Black Screen
your son could have cause your tv to malfunction call in the tech to look at it.good luck.
Apr 01, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi DMP-7 MP3 Player Logo
726 people viewed this question
Top Hitachi Audio Players & Recorders Experts
Man Ana
Man Ana
Level 1 Expert
 Grubhead
Grubhead
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
